painting eblems question
Old Dec 4, 2005 | 03:33 PM
C3 4ME's Avatar
C3 4ME
Default painting eblems question
Ok, so I painted the emblems on my 79 with Testors model paint as I've heard many people talk about doing. The colors came out great, but the problem is all the brushstokes showing. Anyone have any better ideas on how to go about doing this? I hate to replace them, they are in excellent shape except for the worn paint.
Old Dec 4, 2005 | 04:29 PM
cannonfl's Avatar
cannonfl
Back when I was a kid building models I would thin the paint a bit to help smooth out the brush strokes.
Old Dec 4, 2005 | 04:49 PM
DoodahVette's Avatar
DoodahVette
Look in C3 Tech/Performance at "Tony QT--68-Shifter plate" thread. He used a toothpick.
Old Dec 4, 2005 | 06:33 PM
fl_rider's Avatar
fl_rider
With a little thinner the paint flows out better.
Old Dec 4, 2005 | 08:12 PM
C3 4ME's Avatar
C3 4ME
Thanks for the suggestions, I'll give it a try. Of course, once again, something I didnt' think of.
Old Dec 4, 2005 | 11:46 PM
Federot's Avatar
Federot
Thinning the paint a bit, and "dropping" it into the spaces to let it flow and fill the space is an excellent way to do it. Don't actually brush the paint at all. Q-tips, toothpicks, etc are all good tools for this.
Old Dec 5, 2005 | 02:40 PM
redc3's Avatar
redc3
no need to thin unless paint is old. just use plenty on the brush and let it flow into the space. dont be afraid of being sloppy as paint will wipe off the crome on the raised parts.
Old Dec 5, 2005 | 02:49 PM
fl_rider's Avatar
fl_rider
Default "1 SHOT"® Lettering Enamels
A lot of pinstripers use this and it's what I used on mine.
Now the emblems look better than my paint job.
1 Shot Website
Old Dec 6, 2005 | 03:40 PM
68vertible's Avatar
68vertible
Default On Shot B Good Stuff
1 Shot Website
I have some 1 shot for striping and used it on all my emblems.
Old Dec 6, 2005 | 04:09 PM
skydaddy's Avatar
skydaddy
C3 4ME Ok, so I painted the emblems on my 79 with Testors model paint as I've heard many people talk about doing. The colors came out great, but the problem is all the brushstokes showing. Anyone have any better ideas on how to go about doing this? I hate to replace them, they are in excellent shape except for the worn paint.
Man I am doing the exact same thing with the same results. I had heard that this was a problem - I was just going to try and put enough coats on to cover everything up. I figure that I will try to be fairly careful but if I got some paint on the raised parts that I could "scrape" the errant paint from the chromed surface.
I took some before pics but they did not turn out well. I will post some after pics if you do when we get them done.
Old Dec 6, 2005 | 04:20 PM
Clint's C3's Avatar
Clint's C3
After my new paint job, I painted and stripped my front and gas cap emblems a couple of times. I was having major issues with the checkered flag part. I finally stripped the emblems completely and spray painted them white. Then I painted the red background and filled in the bowtie with a gold metallic Sharpie (yes, they make them). Then I used a black Sharpie to color the outline of the emblem and the black parts of the checkered flag. I had my car at a show with lots of eyes and everyone said it looked good. If the Sharpie fades I'll just recolor.
BTW, the emblems from Ecklers look like poop and cost $49.95. I sent both of mine back.
Old Dec 7, 2005 | 08:59 PM
C3 4ME's Avatar
C3 4ME
well, mine look better that they did with no paint left on them, but now there's snow on the ground (I pulled the car out of the garage for better light last weekend) but last weekend it was 60 degrees, so I may not get back to this one for a little while. Thanks for all the suggestions.
Old Dec 7, 2005 | 09:58 PM
71rdster's Avatar
71rdster
Testers has paint pens in most of the major detail colors. Silver, flat black, gloss black, red and white. They are easy to use, leave no brush marks, and they never drip. Available at your local hobby shop. If you get some on the raised parts, just wipe it off with a paper towel.
Orville
Old Dec 8, 2005 | 09:24 AM
Edzred72's Avatar
Edzred72
Hobby and craft stores carry tiny paint brushes that work well for this. (as mentioned above)...drop/dab the paint rather than brush is the perfect technque. Don't use water base paint.
Eddie
Old Dec 8, 2005 | 04:04 PM
redc3's Avatar
redc3
1 Shot Website
no offense, but with el cheapo testors model paint mine appear better than the picture you showed, simply because i filled the space with enough paint to cover the little casting " bumps " that you can see in the red and black areas of your photos. just my .02
Old Dec 8, 2005 | 04:49 PM
Jerry.Everett's Avatar
Jerry.Everett
Default 1 shot Paint
Eastwood carries 1shot Stripping paint.
Old Dec 8, 2005 | 09:05 PM
Edzred72's Avatar
Edzred72
Great idea...1 shot comes with a hardener!!!
Eddie
To painting eblems question
Old Dec 9, 2005 | 12:37 PM
68vertible's Avatar
68vertible
When I did the paint on my '68 console crossed flags on my shift console, I noticed the little bumps in the red, white and black. But other areas of the emblem were also perfectly smooth. I was working with a jewelers glass and the bumps almost looked like they were on purpose to give those areas of the emblem some texture.
I could be wrong, but if they can get the sides and top of the same areas as smooth as they do, I can't help but think the texture areas are on purpose...maybe even to hold paint better if nothing else!
Old Dec 9, 2005 | 08:38 PM
rodesmg's Avatar
rodesmg
Default painting emblem
i read on another forum, a guy stated , he would heat the piece in oven to 200 , take it out and paint it, then put it back in oven at 200 for 30 min, said the paint held up better, and no runs. just don't let the wife see you do it
Old Dec 9, 2005 | 08:45 PM
copter's Avatar
copter
I have allways used a lot of thin tape and spray paint.It takes a while even a couple of days but the finished product looks very good.Don't be afraid of over spray it comes off real easy.
