I burned out a brake light today. After I changed it, I put on the hazard flasher to check if the signals all worked. What I noticed for the first time is that the hazards flash normally in the front, but they alternate from side to side in the back, like on a school bus.
Is this normal? i don't think that I've ever seen this before.
Someone in the past could have installed a "wig-wag" box...not sure why, but people do crazy sheet. Look for a small box wired under the dash that doesn't look like it belongs.
Thanks Tony. I've posted before that my Bubba was evil. A mechanic that knew what he was doing, but not on Vettes.
As I said above, this doesn't narrow it down much. There are all kinds of surprises in my wiring. This is one of the reasons that I posted the question in the first place.
