Drilled rotors ??
Old Dec 5, 2005 | 07:14 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default Drilled rotors ??
Not my Vette for this one, but my Dakota....Has anyone tried drilled (not slotted) rotors ??....I am thinking of trying a set.
ALSO....I have had the oem disks "turned" once....Should I replace them this time....or will they stand another "turn" ??
Thanks for any knowledge on this .... Fred
Old Dec 5, 2005 | 07:27 PM
DR.Jay's Avatar
DR.Jay
Brake rotors have a minimum thickness. If they are under this minimum Reputable machine shops will usually not turn them for liability reasons. A reputable shop will not usually turn a rotor if by turning them will put the rotor below the minimum thickness. I would recommend the drilled rotors for better braking distance, and less brake fade especially if you race, or pull a trailer. I had them on my 95 Firebird. The rotors worked great, only if the woman who had rear ended it had them.
DR. Jay
Old Dec 5, 2005 | 09:03 PM
redc3's Avatar
redc3
i ran them on a s10 for yrs. never had a problem. drilled them myself. god that took forever!
Old Dec 6, 2005 | 03:32 PM
Jims79's Avatar
Jims79
.02 worth. I was watching horsepower TV and they recommended slotted rotors over drilled. The reason the slotted held up better in high speed braking.
Old Dec 6, 2005 | 04:23 PM
kevin1979's Avatar
kevin1979
They sould only be "turned" or re-planed one time. The second time you do them you will only get a short life out of them as they will heat warp much faster and give you a constant "anti-lock" break feel out of a stock system. Spend a little more $$$ and get a lot more life out of a new set of rotors.
Old Dec 6, 2005 | 04:46 PM
comp's Avatar
comp
red-neck anti-lock sucks on ice bad
Old Dec 7, 2005 | 05:17 PM
fotyfobravo
Thanks for all the input...... ......I will do the cross-drilled rotors with ceramic pads and drive it another 90,000.
To Drilled rotors ??
