I have a '72 base model 350, 4-speed, stock....it is my first Corvette. I usually shift gears between 2800-3000 RPMs. Should I be letting it get to 4500 before I shift?
Wondering if it is just personal preference or if I should be taking the engine up to higher RPMs.
The base motor will make good power to about 5000 rpm. If you are shifting at 3000 rpm you are not getting full potential from the motor. In normal driving you can shift at 3000 rpm but if you want to accelerate as fast as you can shift at around 5000 rpm. My cam makes power to 6500+ rpm so I try to shift at around 6500 rpm. It is all where the motors powerband is.
As a pro-gas motorcycle racer, here is my advise.
Get to a Dyno, find out where your horsepower and torque peeks. You may be suprised that you are punishing your motor by shifting higher than what you need to. Next, get to the track, practice your shifts. By the end of the 1/4 mile, if your gearing is correct, you should cross the traps at about 200 to 300 rpm above your peek HP. Be careful though......a bad dyno operator can do serious damage to your motor/trans. Go to only known quality dyno people!!!!
When to shift depends on what circumstances you are driving in. When to shift in stop and go traffic is different from shifting on the strip.
The stock base engined '72 is pretty much finished by around 4,500rpm so going higher does little more than make noise. Sure, you can go higher but you're on the steep downslope part of the power curve. All you need is a working tach and some seat of the pants to realize that it ain't pulling as hard once the tach goes over 4k rpm.
For normal street driving, keeping the revs down avoids unnecessary engine wear. I normally shift 1,2,4 on the street. I just try to keep the rpms up enough to avoid chugging, pinging, or spark plug fowling.
i suppose its a matter of personal tastes, but i try to shift around 3200... that seems to be where you can shift and it feels like an auto if you do it right. around town i usually use 1st to 3rd gear.
We all drive around town and ease around in 1st, 2d or 3rd, but when you want to pull the trigger, you really need to know where to shift. Thats where dyno tuning comes in. Some folks have a natural touch and have a great seat of the pants feel, some don't. The gentleman who started the thread seems he doesn't.
I have the same year & motor, and in normal traffic high RPM shifts are not pratical or possable. For fuel economy, smooth acceleration, and engine longevity I shift between 2000 & 2500.
When traffic opens up...well...let's just say I take her to it's limit. 4500 to 5000.
Eddie
