Block casting numbers and dates
Old Dec 11, 2005 | 04:34 PM
Augustus's Avatar
Augustus
Default Block casting numbers and dates
Is there a way to determine casting dates of 427 BBC
3935439 - 427
3955270 - 427
3963512*-427 late production
Block Codes
A-January
B-February
C-March
Etc. Through
J-October
K-November
L-December
Now how could I tell on the Block the date it was built.. How would it look?
Would it be Casting number 3963512 and date code let's say B and how could I tell if it was built in 68 or 69?
Anyone with expertise here please educate me, as I could use a lesson in poperly identifying correctness of a block's inception.
Thanks all
Old Dec 11, 2005 | 04:59 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
The date code for most of these is on the side of the block between the oil pan and head--I think the drivers side. Later big blocks had the date on the top of the block by the bellhousing.
SHould read something like: B10 9 which would be Feb 10,69.
Old Dec 11, 2005 | 08:05 PM
WESCH's Avatar
WESCH
On the passenger side and normally casted upside down.
Günther
Old Dec 11, 2005 | 08:35 PM
fl_rider's Avatar
fl_rider
Default Here is a good resource...
for casting numbers:
http://www.mortec.com/castnum.htm
Chris B
Old Dec 12, 2005 | 06:36 PM
Vette Dent's Avatar
Vette Dent
68 Big Block #'s are 3916321: 427ci, 390HP, 400HP, 430HP, 435HP or
3935439: 427 ci, 430HP, 435HP
68 Head Cast # 3917215:427 ci, 390HP, 400HP
3919840:427 ci, 435HP, ih
3919842: 427 ci, 430HP, 435HP, ah
Hope this helps.
Old Dec 12, 2005 | 07:10 PM
Corvette69w427's Avatar
Corvette69w427
Hope this helps.
Im pretty sure 3935439 can also be an early 69 427 w/390HP
To Block casting numbers and dates
