Old Gas
Old Dec 13, 2005 | 11:10 AM
Hvymtlc5's Avatar
Hvymtlc5
Default Old Gas
Should be ready to fire up the 454 in the 78 this weekend (said that for about 6 months). Gas in the tank is now almost two years old, but the car's been stored inside the whole time. Can I use it or does it really need to be drained? I think the only additive I put in was a lead supplement when I took it apart in 2004.
Is there a drain plug on the 78 tank?
Old Dec 13, 2005 | 11:15 AM
gerry72's Avatar
gerry72
The gas will burn. It's not a good idea, though. Many of the volitile compounds are gone and it will have a varnish quality to it. Do you really want to risk your 454 over $5 worth of what a couple gallons of new gas would cost? There is no plug, but you can pull the hose off the fuel pump and let it drain out, the put the new gas in it, flush the line with the new gas, hook up the hose and start it up.
Old Dec 13, 2005 | 11:35 AM
Hvymtlc5's Avatar
Hvymtlc5
Wasn't the cost...was the aggravation of getting the old gas drained. Every simple thing always becomes a hassle with this car. Lawnmower gas it will become....
Old Dec 13, 2005 | 11:54 AM
comp's Avatar
comp
drain whats Ez and add fuel drier and a few gal. of fresh gas and try
Old Dec 13, 2005 | 12:06 PM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
Keep it out of the lawnmower, too. Old gas is good for killing grass and weeds that grow through the expansion joints in your concrete driveway and sidewalk. It's more exciting if you light the gas after you pour it on, but the killing power doesn't last very long if you do that. My father taught me that. Well, the burning part I experimented with myself.
Old Dec 13, 2005 | 12:27 PM
Glassbowtie77's Avatar
Glassbowtie77
I when I took my car off the road and garaged it the gas gauge was between 1/4 of a tank and empty. I left the gas in there so that the blatter in the tank would not dry out. When I fired it up 2 years later all I did was add about 5 gallons of fresh gas and a bottle of Chevron Techron fuel system cleaner and started it up. It ran fine and I never had any problems from the old gas.
Old Dec 13, 2005 | 12:31 PM
Strats-N-Vettes's Avatar
Strats-N-Vettes
Friend Request Magnet
Not to be contradictive...but...butt...dont light the gas on the concrete...it will pop and may cause a piece of debris in your eyes...or maybe teach a kid to light his dads drive-way on fire.
"I saw Mr.Bob do it!"
The idea of killing the grass is good though...dont get caught by tree huggers.
For best effects...pour it on fire ant mounds, or ground hornets and light it...it lasts longer.
Jim
To Old Gas
