To do list (C3 projects) for 2006
Old Dec 20, 2005 | 02:26 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Default To do list (C3 projects) for 2006
1) Engine: build a 383 stroker while the old engine still runs
2) Rear suspension: install upper strut rods and a 7-leaf spring
3) Tires: replace tires (255-60 and 275-60) with 245-60 and 295-50
4) Body: install rear fender flares (2")
5) Install 2" adapters to fill the above mentioned flared fenders
6) strip and prep car for paintjob in 2007
7) install 383 stroker
probably won't get it all done
Old Dec 20, 2005 | 02:31 PM
kona's Avatar
kona
Somebodys goina be real busy.
Here's my list- replace the drivers window switch
change out the trailing arm bushings
Drive it, drive it and drive it so more.
Kona
Old Dec 20, 2005 | 02:42 PM
SomeSayIllFixIt's Avatar
SomeSayIllFixIt
my list- Just keep it on the road until I someday have the money and garage to have a real list.
Old Dec 20, 2005 | 04:29 PM
KALAWAY's Avatar
KALAWAY
Had to jump in on this one. Here's my list:
1. New Carpeting
2. Get the Tach working
3. Repair the crack in the spare tire tub
4. New trim rings
5. New decals for the inner door handles
6. New antenna
7. Re-chrome the luggage rack
8. New weatherstripping
9. Replace rubber bumpers w/chrome (I Wish)
10. New Paint Job
11. Sell car, buy a 68-72 convertible
Whew!
Old Dec 20, 2005 | 04:33 PM
flood's Avatar
flood
1. finally put in front sus rebuild kit that I have had all year
2. Install rear shocks
3. Drive the **** out of it.
Old Dec 20, 2005 | 04:55 PM
danboback's Avatar
danboback
Buy and install full 2.5" exhaust system
Headers
X-pipe
Cut-out
Electric Actuators
Flowmasters
Buy and install new valve covers
Save rest of the money for rims and tires!
Old Dec 20, 2005 | 04:57 PM
Twin_Turbo's Avatar
Twin_Turbo
1st: Win Lottery, back up plan: rob bank
Finish front end take off rack install
Finish modding and welding frame
Finish rear suspension w/ upper camber rods and trailing rods + subframe
Finish installing 32 gal. fuel cell and mounting it considerably lower than the stock tank
Finish welding up stainless oval tubing (4" equiv) exhaust (gotta get the tubing first...but no one here sells it so it'll probably be the expensive burns stuff)
Finish intercooler plumbing (gotta land me some more alu tubing and weld elbows)
Finish fiberglass work (flares, rear compartment floor)
paint rollcage
finish front frame extension & air dam
cut threads in my slicks so I can run them on the road without the fuzz noticing it
figure out something for parking brake, integra 4 calipers won't leave room for anything else, backup plan: IR-GT w/ spot calipers.
..oh and get it approved again after finishing..major hurdle there probably
Old Dec 20, 2005 | 04:58 PM
Frankenvette's Avatar
Frankenvette
My List...
Get C5 wheels installed
get new tires for said C5 wheels
install front suspension rebuild kit
actually drive the car with the entire interior installed at the same time
Old Dec 20, 2005 | 05:19 PM
694speed350's Avatar
694speed350
1: replace seat covers and foam. 2 replace or re dye carpet. 3 get rid of off idle surge. 4 trouble shoot inop tach(mechanical).5 drive it
Old Dec 20, 2005 | 05:36 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
See Sig...
Old Dec 20, 2005 | 05:44 PM
worship79's Avatar
worship79
Quite a list, here's mine:
- Headers & sidepipes,
- Edelbrock PowerPackage (heads, cam, the works),
- Upgrade ignition,
- Replace radio and speakers,
- Passenger side window switch,
- Maybe some interior painting.
Old Dec 20, 2005 | 05:51 PM
marshrat99's Avatar
marshrat99
My list: 5 speed Keisler, paint, seat covers, tunes, speakers, headers and side pipes.
Old Dec 20, 2005 | 06:17 PM
theandies's Avatar
theandies
Replace my pilot shaft bushing then reinstall the transmission. Should be done in a few weeks!
Old Dec 20, 2005 | 07:26 PM
phclub's Avatar
phclub
New England Events Coordinator
repair drivers outside door linkage
replace drivers door control
new tires
alignment
detail engine and forward frame
adjust rag top
keeps me busy
Old Dec 20, 2005 | 07:50 PM
DR.Jay's Avatar
DR.Jay
1 Finish sandblasting frame & paint, install new rear shocks
2 Install new clutch assembly while body is off frame (real easy to do it this way)
3 replace mufflers (I hate Rust) Side pipes!!!!
4 Replace fuel lines" "
5 Install TPI (easy to get to fuel tank while body is off)
6 Put body back on frame
7 Install new front clip
8 Finish interior repairs (way to much to list)
9 Tune TPI
10 New paint
11 Drive It Like I have wanted to since I was 10yrs old!!!!!
Old Dec 20, 2005 | 07:54 PM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
Since it will be my first year with the car, I'm going to leave it essentially stock:
1 - Secure and maybe replace the battery.
2 - Install fire extinguisher.
3 - Drive the wheels off of it.
4 - Fix what breaks.
5 - Decide what major projects are needed.
Old Dec 20, 2005 | 08:11 PM
frostbitten09's Avatar
frostbitten09
I am going to be very busy myself.
Install Camshaft And U joints
Clean Interior
Fill/Change all Fluids
Work for Money buying parts PayCheck to Paycheck.
All little interior parts(will update my list this weekend when i go in and make a checklist)
Buy new Carpet/Install
Buy Sidepipes/Install
Buy Heads/Install
Buy Intake Manifold,and carb/Install
Buy New rear Gas Lid/Install
Buy Rear Bumper
Buy Front bumper
Buy Hood
Buy Front and rear pace car spoiler/Install
Fix Right fender that has a chip
Get painted
Also Find and fix rust.
And get tires,and Por-15 Rims.
Buy New(looking maybe 3.73) Rear end
Buy New Street Strip Th350 Tranny.
o ya GO TO SCHOOL
This is what i haev to do from the top of my head . Looks like im a be a busy busy kid.
Almost forgot Fix Horn,Speakers,Radio,EBrake.(busy year for me but i guess it will be worth it in the end)
To To do list (C3 projects) for 2006
Old Dec 20, 2005 | 08:36 PM
moosie982's Avatar
moosie982
Everything,, just everything, and be done in time for my son to drive it to the prom Peace,,, Moosie
Old Dec 20, 2005 | 09:18 PM
enkeivette's Avatar
enkeivette
MY LIST:
  • LOTS OF LITTLE PROJECTS THAT NO ONE CARES ABOUT
  • FIND A CUTE BLONDE TO FILL THE PASSENGER SEAT
Old Dec 20, 2005 | 10:35 PM
ThereIsNoSpoon's Avatar
ThereIsNoSpoon
My list includes:
  • New MSD distributor (with vac advance)
  • Manual trans conversion
  • Sidepipes
