A Jack a$$ screwed up my antenna!
I was parked in front of a coffee shop enjoying the whether and talking to a friend. In the corner of my eye I spotted a Guy checking out my car, which is totally cool. Then, for no apparent reason he decides to pull out the electric antenna with his hand . I tried to stop him but it was too late. I pushed the antenna back in, but every time I turn the radio on I hear a loud (clunk, clunk, clunk, clunk) while the antenna goes up. Is there anything I can do to fix this problem? I just finished a complete restoration and I’m sick of working (spending more $$$) on the car. Your input is highly appreciated.
Thank you
Thank you
Thank you
Thank you
I know, I know...a 178 yr old woman backed up into my Mustang the other day, cracking my plastic plate cover.."don't you look behind you when you back up?".."well I know I should..." what can ya say....
I'd pull the motor and take it apart and see if he striped a gear...maybe you can reset it and lube it if you're not missing a tooth...I honestly know how you're feeling..stupid people...good luck, man
Two days ago I was driving through a parking lot and was stopped at one of the stop signs. Out of the corner of my eye, I see a lady backing up, straight into my back right quarter panel! I pulled up as fast as a could, immediatly put the car and park, and got out to take a look. Sure enough, she was already resting on my car by the time I had pulled up and left about a 1 foot rub mark. "I heard my backing up sensor beeping, but I could of swore you already went by !!" She was an elderly woman so I went easy on her, and most of it buffed out with some wax when I got home. Can still see alittle, but Ill probly take it to my painter soon to see what he can do
I don't know what makes people do stupid things. My boss stopped by yesterday w/his 12 yr old son. I just finished polishing the vette and he was admiring it, while his 12 yr old walked around the car rubbing his hands and every part and touched and grabbed my mirrors, antenia you name it. You know I wanted to yell "Keep your #@*!@#* paws off my car but couldn't .
Thank you
Thank you
Heres another good one. I take my car to the shop a couple months ago and when I go to pick it up there is this 300 pound plus Bubba sitting in my car with a cigarette hanging out of his mouth and of course his set of 50 keys hanging on his belt scratching the **** out of everything.
I ask what the hell are you doing and he said " I aint never been in a Corvette before just wanted to check it out". You just have to wonder what people are thinking when they do such stupid things.
Like my Dad used to say IF IT'S NOT YOURS DON"T TOUCH IT!!!
Kona
Kona
I . Is there anything I can do to fix this problem?
Thank you
Thank you
I removed the broken mast (I forget how, I think I had someone turn on the radio, which caused the electric motor to run in the "mast extend direction" and then I just pulled out the old mast). The nylon cord of the old antenna mast had be damaged by the extention gears of the motor. It had a chewed up appearance. Anyhow, I stuck the nylon cord of the new mast into the opening and had someone turn off the radio. The electric motor then started running in the "mast retract direction," the gears grabbed the nylon cord of the new mast and wound the new mast into place. A perfect repair and it's worked fine since.
See if you can get a replacement mast and look at the installation instructions. Perhaps you won't have to buy a complete new electric antenna. Good Luck
Originally Posted by TedH
Question: did he give any reason for his stupid action?
worst that ever happend to me (so far) was some jack *** at school spray painted silver stripes from the rear quarter all the way upto the front fender. all because some damn sophmores/juniors didnt like our senior prank of blocking off the entire parking lot just for our selfs.
i got lucky and it just buffed out. otheres wernt so lucky, they had smashed in windshields and license plates thrown all over the hill out by the road.
ive got a slight temper when it comes to people messing with my things, so needless to say i probably wouldnt be sitting here right now if i ever found out who it was.
The 7 Habits...and what they'll do to help your group (Summary)
Be Proactive - Fosters courage to take risks and accept new challenges to achieve goals
Begin with the End in Mind - Brings projects to completion and unites teams and organizations under a shared vision, mission, and purpose
Put First Things First - Promotes getting the most important things done first and encourages direct effectiveness
Think Win-Win - Encourages conflict resolution and helps individuals seek mutual benefit, increasing group momentum
Seek First to Understand, Then to Be Understood - Helps people understand problems, resulting in targeted solutions; and promotes better communications, leading to successful problem-solving
Synergize - Ensures greater "buy-in" from team members and leverages the diversity of individuals to increase levels of success
Sharpen the Saw - Promotes continuous improvements and safeguards against "burn-out" and subsequent nonproductivity
But remember, above all else, anybody f**ks with your vette, they die!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!
St. Jude Donor '15
Approach with a smile on your face and hand extended, "Hi, my name is ___________. What's yours?"
While shaking hands and a smile on your face, "Bill, did you know that you just broke the power antenna on my restored collecter car by pulling it out?"
With a smile still on your face, "I'm sure you want to settle this without getting the authorities involved. A reproduction power antenna like that one is about $200, plus labor. If you give me $200 plus your business card, I'll cover the labor and If I can find a reproduction part for less, I'll send you the difference. Does that sound fair to you?"
If he's a man, he should pay you or negotiate a lower price. If he blows you off, with a smile on your face ask "Bill, how do you spell your last name?" Then call the police to report the vandalism.
Of course, I'm sitting here nice and calm typing this. Not spitting nails watching some pinhead damage my vette.
You might be able to tell I am a parent of teen-agers. I am fair and firm but also unrelenting in living one basic observation:
If you tolerate bad manners, they only get WORSE!
I wouldn't have hit the guy but he should at least be told to not go around "playing" with other people's things. :
East bound and down...
....he should at least be told to not go around "playing" with other people's things. :
I agree, going around playing with other people's things will get you trouble, and possiblty a VD as well.
