When my head lights are on ('76 L48), I'm getting a rough idle which I suppose is a leak somewhere in the light's vacuum system. Anyone have an idea of where to look for this??
If you can't hear the leak us a Process of ellimination. The vaccum is drawn from the rear driverside area of your block. Hoses go to a pulldown switch under your steering column, then to the headlight switch, from there to the headlights. Could be anything. Block each hose until you find the one leaking.
most of the time the leak is the acuator seals ,,easy fix,, push the dust cover against the seal and see if the idle changes ..also I have a set of prints I can email you.. email me your address prissyo@aol.com...MIKE boynton beach
I have the diagrams, Mike, but thanks anyway. I'll check those seals.
Jud
