floor covering alternative?
Old Dec 23, 2005 | 03:12 AM
isosceles's Avatar
isosceles
Default floor covering alternative?
is anyone using anything different than carpet? My carpet is worn, but my car doesn't see the street much anymore since I'm mainly bracket racing it.
Do you think Duraliner or something simialr would work? It would be nice to just sweep out the floor with a whisp broom.
Old Dec 23, 2005 | 07:28 AM
firstimer's Avatar
firstimer
Rhino liner! The Jeepers and rock crawlers here love it. Just hose it out after a day in the boonies.
Old Dec 23, 2005 | 08:48 AM
rihwoods's Avatar
rihwoods
....or... just paint it with undercoat that they use under cars..
Old Dec 23, 2005 | 08:58 AM
The Ram's Avatar
The Ram
thus be what im gonna do
Old Dec 23, 2005 | 05:18 PM
ICEMAN59's Avatar
ICEMAN59
I don't know about where you live but here in south Louisiana you don't want undercoating, it will get sticky in the summer
Old Dec 23, 2005 | 06:28 PM
rihwoods's Avatar
rihwoods
I was thinking of the spray on stuff...I live in SO Calif..
Old Dec 23, 2005 | 06:41 PM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
What about linoleum?
Old Dec 23, 2005 | 06:46 PM
gleninsandiego's Avatar
gleninsandiego
I have been experimenting with a number of rattle can options for my dune buggy. The problem with a lot of them is they "chip" or scuff. I would recommend buying a can and testing it before you spray it in your car. Another problem with spraying is the overspray goes everywhere, so make sure you mask everything. A lot of guys use herculiner, which is like a rhinoliner that you roll on yourself. Another thing to consider is how rough a texture you want. Some are pretty rough. Some of the spray on undercoats remain fairly soft and outgas in the sun and heat. Go to Dixieline and look at the options. I ended up using a spray on for coating tools. But I worry it wouldn't be strong enough to take shoe scuffing. I also saw some stuff used on boats that looked like it could take a beating, but it was clear.
Old Dec 23, 2005 | 08:42 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i had a jeep cj 5 20 yrs ago and when i got done fixing it i use rubber matting form JC whitney in it.
Old Dec 24, 2005 | 02:31 PM
Techno's Avatar
Techno
Something fire retardant or at least not a fuel itself.
Just as an option. I didn't use it.
http://www.ultratuff.net/
Old Dec 24, 2005 | 03:06 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Old Dec 24, 2005 | 03:32 PM
kona's Avatar
kona
Bubba says Sticky Tiles.
Kona
Old Dec 24, 2005 | 03:42 PM
carl a's Avatar
carl a
what about astro turf
greg454's Avatar
greg454
How about ceramic tile.
Old Dec 25, 2005 | 01:06 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Hard to better good old molded carpet.
Everything else is hard to remove if u ever deside so. Coatings are not very forgiving once applied. Well i have repaired my floor already and imagine a larger mess/more work if coated. And carpet comes pre-molded which saves time. I recall one can order carpet in different weaves so u can choose something tighter/less fluff/less bulk.
cardo0
Old Dec 25, 2005 | 01:41 AM
gator79's Avatar
gator79
be carefull some of that stuff may not completely harden for years. could be a mess
Old Dec 25, 2005 | 09:40 AM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Will LineX stick?
Old Dec 25, 2005 | 12:54 PM
JonnHeather's Avatar
JonnHeather
I sprayed the bottom of my Corvette and the inside of the box of my Silverado with SEM's bedliner kit. Been in the truck for 3 years and I beat the crap out of it. Never had a problem with it. Great stuff. 200.00 buys you enough to do the bed of your truck or the entire underside of your car. Great sound deadner, heat barrier and very easy to clean. I would highly recommend it...
http://i14.photobucket.com/albums/a3...r/IMG_0928.jpg
http://i14.photobucket.com/albums/a3...r/IMG_0930.jpg
To floor covering alternative?
