71 headlight adjustment
Old Dec 27, 2005 | 11:03 PM
67VetteMan's Avatar
67VetteMan
Default 71 headlight adjustment
Looking at the headlights on the 71 tonight and noticed that the driver side pops up and is not flush with the bottom of the front end towards the bumper - looks like it should pop up another 1/2 inch or so. I think I saw where the adjustment is for the headlight in the down position (lines up nice on both sides in the down position) - but where is the headlight up adjustment??
Thanks,
Old Dec 28, 2005 | 12:39 AM
luerja's Avatar
luerja
Thanks,
I need to know the same
Old Dec 28, 2005 | 01:08 AM
Hammerhead Fred's Avatar
Hammerhead Fred
[QUOTE=67VetteMan]Looking at the headlights on the 71 tonight and noticed that the driver side pops up and is not flush with the bottom of the front end towards the bumper - looks like it should pop up another 1/2 inch or so. I think I saw where the adjustment is for the headlight in the down position (lines up nice on both sides in the down position) - but where is the headlight up adjustment??
There's a stop bolt on the outside/fender side of each headlight bucket.
Looking from underneath you should see a steel brace attached to the underside of the bucket with a stop bolt and (if you're lucky) a rubber bumper still on the head of the bolt. You can adjust the height using this bolt.
Old Dec 28, 2005 | 02:47 PM
67VetteMan's Avatar
67VetteMan
Found the bolt on the drivers side - no adjustment needed because it doesn't even come close when the headlight stops popping up. The bracket that contains the down adjustment screw seems to stops any additional up movement...
BTW: The bolt didn't have the rubber bumper. The passenger side does come all the way out (as mentioned earlier) and it doesn't even have the stop bolt on the bracket.
Any other suggestions to the headlamp bucket for adjustments that may help?
Thanks,
Old Dec 28, 2005 | 05:05 PM
palazzopl's Avatar
palazzopl
hows the adjustment on the accuator.remove the pin and see if the light go up to the stop
Old Jan 1, 2006 | 12:11 PM
67VetteMan's Avatar
67VetteMan
Will try the screw adjustment (and pin, as you suggest) on the actuator rod next.
Thanks.
To 71 headlight adjustment
