1982 Corvette battery problem
Old Dec 29, 2005 | 05:17 PM
The Alaskan's Avatar
The Alaskan
4th Gear
Default 1982 Corvette battery problem
The battery in my 1982 Corvette goes dead after three days of just sitting in the garage. The battery is new and I just had the alternator rebuilt. Any ideas on why this is happening?
Old Dec 29, 2005 | 07:04 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Your getting a draw from somewhere. make sure nothing is in your
cigarette liter hole, like coins.
Old Dec 29, 2005 | 07:47 PM
startwith80vette's Avatar
startwith80vette
didnt you just post this thread this morning, dont double post threads it gets annoying
http://forums.corvetteforum.com/show...5&forum_id=119
Old Dec 29, 2005 | 07:50 PM
RoadrashOU812's Avatar
RoadrashOU812
I believe coins in the lighter hole would short the circuit and blow a fuse not create a draw .
But obviously , there is a circuit draw created from somewhere . Put a test light between the positive cable and the battery , the light should be on if there is a draw . Pull fuses one at a time to see which one makes the test light go out . Then you can determine where your draw is coming from .
Old Dec 29, 2005 | 08:52 PM
johnt365's Avatar
johnt365
excellent troubleshooting tip. i love this forum!
If you dont already have one, i would get a battery disconnect kit at autozone for $5. i always disconnect the battery when not in use. vettes are easy too since it is right behind the seat.
this will at least prevent it from draing while you work on it.
good luck hunting the source.
To 1982 Corvette battery problem
