Im needing to remove the coil springs for a front end rebuild on my 81. Will a set of coil spring compressors fit in the space to slightly retain/compress the spring for lower control arm removal?
You need internal spring compressor. That goes up in were the shock is. I was suprised how easy the job of taken out the springs is. I went to my local tool rental place,and rented the internal spring compressor for $14.00 a day. If you want to buy it. It cost around $75.00.. I bought one at the Turkey Rod Run in Daytona for $20.00
you dont need a compressor to remove the springs. just a floor jack. maybe a chain for safety sake. its not that big of a deal once youve done it a couple of times
You can borrow a compressor from Autozone for free as well. You just have to pay a deposit when you pick it up. That's what I did when I changed my front springs.
When I did my front end work, I got the spring compr. from Autozone as mentioned above. I couldn't figure out how to make it work up my towers so I used a floor jack and just unloaded the spring slowly and carefully, with inner control arms in tact. I agree with redc3.
From: San Diego - Deep Within The State of CONFUSION!
All you need is a floor jack under the lower control arm. Spring compressors make it hazardous and time consuming. After the lower control arm is supported firmly (in the spring pocket) by a floor jack, you release the lower ball joint. Lower the jack slowly, and let the spring unload. It is very simple and stress free to do so.
Trust me I am scared of springs too but if you will follow the instructions on lars's technote about front suspension rebuilds you will be surprised at how easy and safe this job is (if you have a small block).
I just did my 76 and did not use a spring compressor. I had a floor jack under the lower control arm and let it down until there was no pressure on the spring. i them pulled the arm down and pulled out the spring. if you ever used one of those compressors, they are a pain and spce is limited. I just did the reverse to put the new one in. Make sure it is sitting in the control arm correctly.
BE VERY CAREFUL!!!!! THIS WORKED FOR ME BUT YOU MUST BE THE JUDGE OF WHAT IS A SAFE WAY TO DO THIS!!!!!!!!!
Let me say this. I used a floor jack to take the springs out. Took about 40 min. for both sides. Getting them back in wasn't that easy with a floor jack. With the spring comps I had both sides in and sit in the pocket, lower ball joint connected in less than 45 minutes. I don't like to fight with anything that can take my hand ,finger. When I can do it the easyway. Just my 2 cents.
with the engine out, I used my cherry picker and attached a chain to each bolt on the lower control arm shaft, took up the slack, removed the bolts and lowered the arm down, very easy. Now with the body off I will just strap the frame to the cherry picker legs and jack the lower arm into place. I have never used a floor jack for this job, but it seems that the cherry picker gives you a little more control. Obviously wouldn't work with the engine in, wouldn't be enough room. Bob
that is verry good plan. it should work perfectly, someone was using there head, love the power of the forum
