2 questions
Old Jan 1, 2006 | 07:41 PM
694speed350's Avatar
694speed350
Default 2 questions
I have 2 questions. 1 the car i have has the air pump removed by one of the previous owners and plugs installed in the exhaust manifolds. does any one know what the plug sizes are? i changed the plugs after i got the car and hit one of them with my spark plug wrench and it came loose actually fell out. tried to re-install it no go. anyway it is missing now and i have an exhaust leak. 2ond question: when starting car at certain times the fan hits the fan shroud. after the engine warms up it stops. what could be causing that? checked the fan read about the bearings in the water pump no play. what could be causing this?
Old Jan 1, 2006 | 07:46 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
Maybe 3/8 pipe thread? Otherwise remove another and take it with to match up.
Does the engine do this on acceleration too? Could be the LH motor mount. Otherwise check the mounting of the shroud.
Greg
Old Jan 1, 2006 | 08:25 PM
Supersportt396's Avatar
Supersportt396
Default Vette
I agree with the motor mount, but check both side.
Old Jan 1, 2006 | 08:55 PM
71redskin's Avatar
71redskin
those air holes are 1/4 in. pipe plugs if i recall..
Old Jan 1, 2006 | 10:33 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
also check the fan clutch and make sure its not going bad
Old Jan 2, 2006 | 01:45 AM
jetvette's Avatar
jetvette
Regarding the air plugs. Were emissions air pumps used in '69? Maybe I'm just gettin too old for the memory I'm workin with. Guess it really doesn't matter,you still need the 1/4" NTP plug.
Old Jan 2, 2006 | 11:29 AM
694speed350
I couldn't remember either. but according to a restoration guide i have says that the a.i.r was on all 68-69 vettes.
To 2 questions
