OK, I put on 4" hooker side pipes without the mufflers, and my God I wish I did this ten years ago. My only problem is rust starting to accumulate on the area of the pipes where the side tubes connect to the headers. What is the best way to remove this rust without damaging the finish on the headers?
my jet hot coated supercomps (undercar) have some surface rust. Bummer! In fairness to jet hot they told me I could send them back to them for recoating, but I am just not up for taking them off. Haven't tried cleaning them up, but I am not optimistic.
I don't know if I need a die grinder yet. The pipes are not that old so it is only light surface rust. I am worried that rust remover or converter will stain the headers.
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
wet sanding is pretty aggressive i would not do that first....try toothpaste first...seriously it has a fine grit and work it in with your finger in an inconspicous spot
crest or ultrabright? hmmmm... ultrabright sure sounds better, deoesn't it??
