I reattached the tach cable for the 71 into the back of the tach - now the other end will no longer reach into the back of the distributer. How come they made these cables so short? Anyone else have this issue with their speedo / tach cables?
Is there a cable extension - I need about 3 inches or even less to get it to reach the back of the dist easily.
Thanks,
You reattached the cable and now it is 3 inches short Aprils fool day is still 3 months away.
Naw - the cable was never connected to the back of the tach to begin with... I pulled apart the dash and upon reinstallation, I decided to disconnect it from the back of the distributor and connect it into the back of the tach first, then connect it to the back of the distributor.
Both places - back of the tach and back of the distributor - are tight fits for my hands so I thought I was picking the best of 2 evils. Now sure the cables ever fit
And it's not 3 inches short but it could use a few more inches to connect correctly... rerouting it is not possible unless I put another hole in the firewall to get it closer to the distributor....
do you have the distribtor in correct location.
Now that I read your post it has come back to my mind,mine was to long so I cut it to length and recrimped the screw on housing,then what I did (very carefully )was grind the cable itself to a square to fit in the square slot,it has been working great.
(note ) it is difficult to grind the cable,if you go to deep then the small wire just falls apart.
I used a piece of old cable to learn on then I did the cable.
Distributor seems to be in the correct location...
So no one else has had an issue with a short tach cable? (all puns aside) I even had difficulties with the tach cable in my 67 when I had to replace the tach cable gear.
The orientation of the distributor can play a big role in the problem that you are describing. Do you have a picture of the problem that you can provide us with?
There was a Chevy bulletin about clocking a distributor to help alleviate the problem with the binding cables. Instead of having your distributor at the "normal" position, you may have to rotate it clockwise by one spark plug wire position. When you do this, you will need to rotate your spark plugs counterclockwise by one position to maintain the correct firing order. The position between the rotor to the plug wire will not change, and the firing order will be the same. The relative position of the #1 plug in the firing order will not change. The relative position of the vacuum advance cannister will change, but that has no effect on the timing of the engine.
By rotating the distributor clockwise the tach cable connection will align better with your cable, and it should almost connect at a direct input, rather than the 90 degree bend you are trying to make fit.
The cable extension on the Mid America website states it's 9 inches long - others in this thread have stated an issue when the cable was too long. As you can see from the pict - I'm off by way less than 9" - a 3" extension would almost be better...
The cheapest option would be rotating the dist clockwise and rotating the plug wires counter.
Thanks for all the options.
Thats what I did on my 71....first tach cable failed due to that 90 deg bend....rotated the dist and the new one fit fine with no binding.
Thanks everyone for the responses. I rotated the dist clockwise one plug and rotated the wires counter clockwise. Nice straight tach cable - that actually attaches now...
and works!!!!!!!!
Reason: added more
