charging battery from engine compartment/
Old Jan 2, 2006 | 09:19 PM
driver68's Avatar
driver68
Default charging battery from engine compartment/
On a '72, is there anywhere from the engine compartment that the battery can be charged (with a trickle charger)? its sort of a pain to always access the battery compartment and charge it from the inside of the car.
Old Jan 2, 2006 | 09:30 PM
trw's Avatar
trw
Use the hot alt bolt and any ground.
Terry
Old Jan 2, 2006 | 09:45 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i would only do this on the battery you don't want to find out you have a wiring problem from mice or anything when you have a battery charger hooked up and you are watching a game and eating popcorn
Old Jan 2, 2006 | 09:49 PM
63C2splitter's Avatar
63C2splitter
CF Senile Member
St. Jude Donor '08
I have "hard wired" a Battery Tender harness on my 63 and have the hook-up in the front grill (had to add about 4 feet of wire to the harness provided). After driving, I hook up the harness (quick connect) from my work bench.
Good Luck.
Old Jan 2, 2006 | 10:27 PM
kona's Avatar
kona
Not sure if they even work but I have seen battery tenders that charge thru the cigarette lighter.
Kona
Old Jan 3, 2006 | 07:02 AM
Burnt71's Avatar
Burnt71
Terry
not sure now.
Old Jan 3, 2006 | 01:48 PM
Jims79's Avatar
Jims79
Battery Tender makes a sub-compact tender that's the size of a pack of smokes or the mouse of your PC. You can attach it & leave it attached to the battery and plug in cord you can hang in a conveyant spot under the car and plug in when not driving.
Old Jan 3, 2006 | 01:59 PM
lil75vette's Avatar
lil75vette
Terry
hmm... correct me if i am wrong, but i don't know if i would do this as... couldn't you backfeed through the alternator creating dead spots?...
that is unless you connect a diode befor your alternator...
just a thought sorry if i am wrong
Old Jan 3, 2006 | 02:36 PM
Burnt71's Avatar
Burnt71
Probably safer going to the starter . Hook a wire to the positive that goes back to the starter ?
Right ?
Old Jan 3, 2006 | 02:43 PM
bobs77vet's Avatar
bobs77vet
you know the right way to do this is to go straight to the battery.....if you don't like crawling around back there then hard wire a set up to the battery.....i wouldn't be fooling around with this set up, fires do happen and they really get your attention
Old Jan 3, 2006 | 03:57 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
What's the difference, starter, alternator or at the battery. Unless you have a physical breakdown, they are all connected to the battery. Thus you can charge it from the back of the alternator since it is on top. anywhere you have 12 volts (or 14 whatever it is) and a ground you are as good as at the battery terminals.
I charge from the alternator fwiw.
Old Jan 3, 2006 | 04:07 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Unless you disconnect the cable from the battery, it is all connected anyways.
Old Jan 3, 2006 | 04:33 PM
shafrs3's Avatar
shafrs3
Charge from the Alt Batt lug. I do it all the time.
Old Jan 3, 2006 | 06:20 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
I have a float charger. It's about the size of a pack of cigarettes. In the kit came 2 adapters for the battery, one had alligator clips, the other had loop end fasteners.
I disconnected both cables, put the loop fasteners in, and tightened the cables. I then ran the connector out through the bottom of the battery box and zip tied it to ???? can't remember.
I reach under the car and fasten the float charger to the wire hanging below the battery box. Has worked that way for years for me. Chuck
To charging battery from engine compartment/
