Jacking points with sidepipes.
Old Jan 3, 2006 | 06:40 PM
jotto's Avatar
jotto
Default Jacking points with sidepipes.
Have got my sidepipes and suddenly wondered about jacking the Vette after installation.
Will the standard jack reach under the pipes without fouling? If I needed to change a wheel at the roadside....wondered if I could.
Also, on a standard car setup, are there any safe central points to jack up both wheels at same time front and rear?
Thx.
Old Jan 3, 2006 | 06:49 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
With my lowered front end, I have to drive up onto a couple 2x4's before I can jack her up. In the rear I jack from the differential.
Old Jan 3, 2006 | 06:54 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I have to take the front wheels of to get the lift under it. I also have to use these special made brakets.
Old Jan 3, 2006 | 07:00 PM
jotto's Avatar
jotto
ok so being dumb now, how do you jack up the front to take off a wheel? lol...also do you have any pics of the brackets you use?
Old Jan 3, 2006 | 07:05 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
My uncle friend custom made them out of stainless steel for doing work on vans and trucks. Basically all they do is raise the front jacking points since I only use the front ones. You completely take out the pad put the raiser in and then put the pad in the bracket. The female part is on the top and the male on the bottom. Ill get pics next time I go down to work on the vette.
Old Jan 3, 2006 | 07:56 PM
baja216's Avatar
baja216
I built the same setup that Jughead talked about with 2x12's. It works out really good. I also bought two scissors jacks for the rear. They're pretty cheap at harbor freight etc.
Old Jan 3, 2006 | 08:13 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
baja216, very nice ride, have you added front fender louvers, and if so how did they fit. I always like them, just thought they may fall out.
jotto, I have a complete ground effects body kit and I'm in the same boat when it comes to jacking. With my floor jack I pull the center lift out, slide the jack under and place the center back in. My 79 is 4 inches from the body kit, off the ground.
Old Jan 3, 2006 | 10:08 PM
68/70Vette's Avatar
68/70Vette
As I recall, the standard Corvette sissors jack will work even if you have sidepipes. However you must lay the jack flat (sideways) to fit under the sidepipes and then you can stand it up correctly and lift the car. In my garage I used the stock sissors jack to lift the car up an inch or so and then, I was able to use my floor jack.
I used the above technique in closed spaces. However, if the car is outside of a garage (or you have a big garage) you can just use a floor jack to pick up underneath the front crossmember, or lift at the differential spring mounting plate.
When I use my floor jack, I have a hockey puck on the lifting section. The hockey puck doesn't dent or deform my frame/crossmember parts. My hockey puck cost $1.59. Fantastic investment. Someone in the forum suggested the hockey puck idea. (Maybe some day in the future Snap-On will sell a floor jack hockey puck and charge $15.90 for it.. Just trying to funny. I like Snap-On's stuff.)
Old Jan 5, 2006 | 04:45 PM
jotto's Avatar
jotto
Just what I needed, thanx dude....now to get on and install the pipes!
Old Jan 5, 2006 | 06:17 PM
jlaw68's Avatar
jlaw68
i have the 69 repo's on my 78 and i have no problem getting a floor or a sissor jack under mine, but it is stock height.
Old Jan 5, 2006 | 07:53 PM
baja216's Avatar
baja216
The louvers were on the car when I got it. They just screw in with two screws.
Old Jan 5, 2006 | 10:29 PM
Edzred72's Avatar
Edzred72
Yes this works well....as long as you use a 2"x6" or larger piece of wood between the jack pad & crossmember/differential to avoid crushing the crossmember.It also distributes the load evenly.
Been doing this for years with NO damage.
Eddie
Old Jan 5, 2006 | 11:31 PM
68/70Vette's Avatar
68/70Vette
Good idea. But as far as I can tell, my hockey puck has been working well for the last year. When I lift at the front crossmember, I lift at the front edge. I'd be wary of lifting in the middle of the crossmember since it might dent (although my front crossmember has been dented in). Well....OK, I dont have an engine in my car!! When I put the engine back in the car, I'll recall your 2X6 suggestion. But basically the hockey puck seems like a good idea, in general. If you've painted your frame, etc, you dont want a metal jack to contact the surfaces on liftoff. So, the rubber puck is also a good and very strong protecter.
To Jacking points with sidepipes.
