Por15.....fyi
Old Jan 7, 2006 | 11:22 PM
David Ey's Avatar
David Ey
Default Por15.....fyi
Did you ever put the lid back on a can of POR15 and then try to remove it a few days later? Can't be done.
Drill a small hole in the lid near the edge and another in the side of the can near the top, opposite the hole in top. The top hole is a vent so you can pour from the side hole into another container. Plug both holes with sheet metal screws that fit tightly and seal. Give the can a shake to coat the screws inside to help seal and refrigerate for longer shelf life. Refrigeration not absolutely necessary but, NEVER EVER REMOVE THE LID OF POR15. It makes good glue.
Old Jan 7, 2006 | 11:53 PM
68/70Vette's Avatar
68/70Vette
Good suggestions.
POR15 is basically "Superglue" with pigment(i.e. it's an isocynate)
. Most paints harden by outgassing volatile components. POR15 does not harden by outgassing. POR15, like "superglue" hardens by absorbing atmospheric water vapor. Once POR15 is exposed to atmosperic water vapor it's going to start to harden. This is why there's a problem with putting a lid back on a can of the stuff.
rcread's Avatar
rcread
Don't they recommend putting plastic wrap under the lid when you re-seal it so it won't stick?
Old Jan 7, 2006 | 11:55 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Use it all in one day. Don't be lazy!
Old Jan 8, 2006 | 12:07 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I always use plastic wrap under the lid. The lid will come off again when you need to use it again. But the POR15 will still set up if you leave it on the shelf long enough. I have had a can set up while on the shelf before with the plastic wrap being used.
Old Jan 8, 2006 | 12:29 AM
rosslato's Avatar
rosslato
i never remove the lid either, just do the above
Old Jan 8, 2006 | 09:04 AM
jlsru's Avatar
jlsru
Cruise-In V Veteran
This is what I did.Worked for me.
Old Jan 8, 2006 | 09:14 AM
JAMES69's Avatar
JAMES69
I still buy (many) 6 packs of the small cans and use saran wrap before I put the lid back on, never failed me. Also get the solvent if you ever want to get it off your skin quickly!!
Jim
Old Jan 8, 2006 | 09:31 AM
Edzred72's Avatar
Edzred72
YES they do. They also recommend cleaning the rim seal of all access before sealing. Using this method of sealing, I've got pint cans that are over a year old that are perfectly good. Stuff is too expensive to let harden.
Eddie
Old Jan 8, 2006 | 12:09 PM
Maine Vette's Avatar
Maine Vette
Well if you don't take off the lid you can't stir it... According to the instructions you shouldn't shake it because it leaves small bubbles in the paint that never escape/pop so it doesn't give as nice of a finished surface. (I've always stirred it so I can't vouch for whether that happens or not).
I take off the lid and pour whatever amount I need into a seperate container (shouldn't paint out of the can) then get the excess off the cap with a brush. To prevent the lid from sticking I use a piece of paper towel with a little laquer thinner to clean things up. Did my whole frame and then some and never had a problem doing it that way...
Old Jan 8, 2006 | 02:24 PM
Muddywaters's Avatar
Muddywaters
I bought a couple of small cans (about same size) from Orchard Supply... after using what I needed on project, I poored the remainder in those cans... The new cans are cheap!
Old Jan 8, 2006 | 03:07 PM
82MDVette's Avatar
82MDVette
I did as they suggest in their directions and used the plastic wrap under the lid after wiping the rim clean. Works like a champ!
Old Jan 9, 2006 | 08:48 AM
70BBvert's Avatar
70BBvert
Same as you guys, I clean the lip & use some plastic wrap. Then I put the can in a zip lock back and get as much air out as possible.
Works so far, couple of cans are more than a year old.
Jim
Old Jan 9, 2006 | 11:21 AM
75 Hot One's Avatar
75 Hot One
I use a plastic kitchen measuring spoon to scoop out the paint into a separate smaller container since all my jobs have been fairly small. Then I cover the original can so it's not left open. My quart can is still about half full and about 8 yrs old. I noticed last summer it was starting to thicken up but was still usable.
Old Jan 9, 2006 | 01:47 PM
David Ey's Avatar
David Ey
Well, thanks for the replies. I'm glad to know the plastic wrap works. I was told it didn't.
Old Jan 9, 2006 | 02:00 PM
BLVette75's Avatar
BLVette75
OK..Here is another question. How much Por15 is needed to paint the frame? What size cans is it available in ? Are there any tips or concerns when applying the stuff? Where do you guys buy your Por15, about how much? I will be using it soon....
(ok... it was more than one question)
Thanks,
BL
Old Jan 9, 2006 | 07:13 PM
Maine Vette
I used the all in one special from the www.por15store.com
It was enough to do two coats of POR-15 and one top coat on my frame, control and trailing arms, and a few other pieces.
To Por15.....fyi
Old Jan 10, 2006 | 03:01 PM
BLVette75's Avatar
BLVette75
BL
Old Jan 10, 2006 | 04:41 PM
palazzopl's Avatar
palazzopl
can it be bought locally or do you have to order it.. I need about a pint to do the lower birdcage area
Old Jan 10, 2006 | 05:33 PM
Kenny Bonnell's Avatar
Kenny Bonnell
I bought mine from their web site. You can call them and they can tell you how much you might need and what else to prep the area you are going to paint. I just finished my fuel tank last night, and will start on my frame this weekend. The tank looks great, I used silver.
