differences between 350/300 and350/350
Old Jan 8, 2006 | 11:24 PM
694speed350's Avatar
694speed350
Default differences between 350/300 and350/350
What are the differences between a 350/300 and a 350/350 engine?
Old Jan 9, 2006 | 12:21 AM
MoneyPit's Avatar
MoneyPit
The 350/350 may have been a solid lifter cam. However, I am sure someone will step up and give us the answer.
Old Jan 9, 2006 | 12:35 AM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
St. Jude Donor '10-'12, '25
Old Jan 9, 2006 | 01:33 AM
1971corvette's Avatar
1971corvette
I had a 350 / 350 horse in a 69 impala,it was a hydralic cam,as a matter of fact this is the motor I will be putting in my car some time.
Old Jan 9, 2006 | 08:24 AM
moosie982's Avatar
moosie982
Default 50 horsepower
Hey, the 350/350 was a hi-perf. motor, better innards. the 350/300 was a regular passanger car motor, back in the day I could have told you exactly which parts were different but that was a long time ago and a bunch of trivial crap has seeped into and out of my overtaxed and under utilized brain,,, Someone will chime in I am sure,,,urban legend has it that the 350/350 was just a LT-1 with a hydraulic cam ,,but I dont think so ,,,,,Peace, Moosie
Old Jan 9, 2006 | 09:00 AM
stingr69's Avatar
stingr69
The L-46 350/350 was a hydraulic cam version of the LT-1 with a few other differences in the carb/ign etc. It is down a few ponies because of that cam difference but it had all the good stuff in the bottom end.
If you lower the compression down to 9:1 on a 350/350 it will basicaly become an L-82. Same cam just lower compression smogger heads.
-Mark.
Old Jan 9, 2006 | 09:15 AM
big_G's Avatar
big_G
Better cam, bigger valves in the heads, different carb. jetting, different distributor vacuum advance, Higher compression (11:1 v. 10:25), Larger harmonic balancer.
Old Jan 9, 2006 | 04:24 PM
sb69coupe's Avatar
sb69coupe
L-46 had a steel crank where the 300hp was cast iron. Also used forged pistons instead of cast, had "pink" rods, larger valves, higher compression heads, and a more radical camshaft grind. The 350hp motor was not offered with the auto trans, since it didn't produce nearly as much low end torque as the base motor.
Old Jan 9, 2006 | 05:16 PM
Gordonm's Avatar
Gordonm
The 350/350 also used a cast iron manifold with a Qjet carb. It did have a good bottom end like the LT1 and decent heads but did not have the cam intake or carb of an LT1 motor. My father had one that we put in a better cam with the LT1 intake and carb. It was a very fast car for pretty much stock stuff.
Old Jan 10, 2006 | 06:47 AM
fugawi's Avatar
fugawi
hey, isn't this a tech question? why did it get moved to general
To differences between 350/300 and350/350
