Int Ready to go back in
Old Jan 17, 2006 | 07:46 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Default Int Ready to go back in
If I can remember where all these parts go..
Old Jan 17, 2006 | 07:53 AM
KALAWAY's Avatar
KALAWAY
Is all that new, or did you paint it?
Old Jan 17, 2006 | 08:10 AM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Door panels new still need to build them up..new black panels (center console) and lens..all the other parts have been redyed..took 2 quarts..
Old Jan 17, 2006 | 08:55 AM
Blue 74's Avatar
Blue 74
That is a great picture !
Old Jan 17, 2006 | 09:02 AM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Where they go might not be as important as WHAT ORDER do they all go back in I'd like to do that with mine some day. good work!
Old Jan 23, 2006 | 09:08 AM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Default Got some of it back in !!!
If you check my home page you will find a link to some more pics of project 77..
Old Jan 23, 2006 | 10:25 AM
samson80's Avatar
samson80
where do you find the parts to replace the storage compartments, or did you fabricate them, mine are beyond repair.
Old Jan 23, 2006 | 11:08 AM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
The frames are available from many of the venders here..
I reused the doors. It is a bit time consuming but not hard at all I have some pics of the process. I can post if you like.
1. You will need to disassemble your doors remove all hardware and old framework and carpet.
2. Next you will need to file or grind the door edges a little at a time until the new frames fit.
3. Fit and trim new carpet be sure to cut the carpet around the edges at a 45% angel so the trim will be able to compress all the way down.
4. After you get everything fit flip the door over with trim and carpet and clamp it to you bench with a piece of wood or something long enough to cover one edge at a time, this will allow you to compress the trim and install new screws to hold it on.
Old Jan 23, 2006 | 01:01 PM
jn76vette's Avatar
jn76vette
St. Jude Donor '08
Looks great
Old Jan 23, 2006 | 05:13 PM
harrin's Avatar
harrin
looks like way to many parts, I'd scrap that piece with the too large holes in it!
Old Jan 23, 2006 | 10:02 PM
fl_rider's Avatar
fl_rider
That is so cool!!!!!!!!!
Of course post the other pics, I would like to see how it was done.
Thanks for sharing!!
Old Jan 23, 2006 | 10:07 PM
comp's Avatar
comp
Old Jan 23, 2006 | 10:18 PM
1981 corvette's Avatar
1981 corvette
Looks Great, keep the pics a coming.
Old Jan 27, 2006 | 10:02 AM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Default Ok got most of it back in !!!
Link to Project 77
http://peachstateposse.com/ipw-web/gallery/album243
To Int Ready to go back in
