Peg Board Users
Old Jan 17, 2006 | 02:57 PM
JustForFun's Avatar
JustForFun
Default Peg Board Users
Anyone using pegboard in your garage to hang tools? how well does it work for you? Any suggestions?
Im wanting a way to have better access to my tools without having to dig thru a tool box
Old Jan 17, 2006 | 03:49 PM
kona's Avatar
kona
I use it you just need to build a 2x4 frame to hang it on and give it support.
Old Jan 17, 2006 | 03:52 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
My garage is unfinished and uninsulated, I just screwed the pegboard directly to the studs. I'd like to buy about 5-10 more sheets and cover all of the walls. Right now I have 4 full sheets. - not enough to hang and neatly display stuff.
Old Jan 17, 2006 | 03:55 PM
big_G's Avatar
big_G
I used 1x2 furring strips to off-set the peg-board a little to let the hangers have clearance. Paint the peg-boards semi-gloss so it will clean up nicely!
Old Jan 17, 2006 | 04:07 PM
alanbl's Avatar
alanbl
There are actually packs of screws with plastic collars designed specifically for pegboard. These are spacers giving you the correct clearance between the wall and the board. I put anchors in the drywall, and screwed these guys in and the pegboard works great. Very easy.
Old Jan 17, 2006 | 04:36 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
I use this stuff.
PVC Slatwall
It holds 25+ lbs extended 12" out. It washes down with a hose and looks great.
Old Jan 17, 2006 | 04:43 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
one wall in my garage is peg board, I absolutely love it
and the only pic I could find just happens to have my mug in it along with a friends
To Peg Board Users
