pacecar style front spoiler
Old Jan 17, 2006 | 10:41 PM
tunnelback's Avatar
tunnelback
Default pacecar style front spoiler
Hi all, I'm new to this site and need some feedback: I intend to put a pacecar style spoiler on my '77. anything special I should know before ordering? ie. one piece, three piece, fastening tricks etc...
Thanks, Mark
Old Jan 17, 2006 | 11:22 PM
VETTEVIC's Avatar
VETTEVIC
Yea, dont toss ypur stock one till your are done, youll need it to mount the new one
Old Jan 18, 2006 | 01:42 AM
DMONSVETTE's Avatar
DMONSVETTE
What size tires are you running up front. 15x60x255 might rub if it's a Indy 3-piece, the two piece might give alittle bit more room but not much. Before you buy one you better go turn your wheels all the way to left and right and check to see what kind of clearance you have.
HTH
Old Jan 18, 2006 | 09:11 AM
Ganey's Avatar
Ganey
The factory 3 piece is flexible- very good w/ low clearance.
The Indy ft. spoiler designed for our Vettes w/ wind tunnel scoops up air for cooling, cleans up airflow underneath & sweeps the airflow around the front tires.
Rec. for all 68-79 ! I put mine on as soon as possible, so early that the paint matches & it appears original.
Old Jan 18, 2006 | 09:29 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I got the 1-piece from Eckler's. You have to re-use part of your original spoiler when you install this one, installation is a piece of cake.
Old Jan 18, 2006 | 02:14 PM
skydaddy's Avatar
skydaddy
I have a copy of both the 1 piece and 3 piece sitting on my desk. I cant decide which one looks better. What are the pro's and con's for each? What made you choose one over the other?
Old Jan 18, 2006 | 02:33 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
The 1-piece fiberglass spoiler is cheaper, it's easier to paint (it comes with primer already on it)... I extended the upper corners a little to blend it into the fenderline...
On the other hand ... fiberglass can break ....
Old Jan 18, 2006 | 05:37 PM
Brettmc's Avatar
Brettmc
Sometimes the ends of the 3-piece don't match up exactly after installation....
Brett
Old Jan 18, 2006 | 05:52 PM
skydaddy's Avatar
skydaddy
Hey Brett - long time no talk
RedBad1979 - I like the way yours looks but I dont think that I want to (could make it look that good) try extending the edges. I remember when you originally posted with your pics. I think that it looks great.
Old Jan 19, 2006 | 09:51 AM
tunnelback's Avatar
tunnelback
Default spoiler
OK thanks guys, I guess I'll go with one piece. I really like the idea of extending the corners (thanks RED'79) I will also go with goodyear 255/60 15 . So I will let you all know and I will post pics (soon as I can figure out what "paste" "drag" "upload" "download" mean)
Old Jan 19, 2006 | 09:08 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
skydaddy and tunnelback,
it is really a very easy job to extend the corners - it's only fiberglass. I used some mini files to get the stuff in shape
here's another photo (the tire sticks out because at that time I experimented with spacers) :
Old Jan 31, 2006 | 11:50 AM
Hvymtlc5's Avatar
Hvymtlc5
REDBAD79 -- Is this the spoiler you used??
http://www.ecklers.com/product.asp?p...dept%5Fid=1738
To pacecar style front spoiler
