What Is It?
Jan 19, 2006 | 05:01 PM
What Is It?
I've got a 72 T-Top 350 with Automatic, about 80,000 orginal miles and looking under the hood I saw something that I've never seen on a vette before and can't find it in any books. It appears to be a stainless steel plate that is mounted between the carb and the manifold. It has the firing order stamped on it and a part number, Anybody know what it's for, or what it is?
Greg
Jan 19, 2006 | 05:04 PM
St. Jude Donor '07
Carb spacer. It is supposed to give a little more horsepower and better gas milage. It does give better gas milage my dad tested one out.
Jan 19, 2006 | 05:05 PM
2015 C2 of Year Finalist
it is a carb spacer. gives your intake more of a ram air effect
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Look like this?
Jan 19, 2006 | 05:08 PM
HMMM.I always thought it was a heat shield....dumb me....
I've seen those before and they are thick, like an 1" or more, this is very thin, less than the gasket and wider than the carb itself.
Greg
Jan 19, 2006 | 05:10 PM
Jughead, thats it ...............never seen one before, now I have.
Greg
Jan 19, 2006 | 05:12 PM
St. Jude Donor '09
Quote:
Greg
Hold on to it. GM ain't makin them any more. It might have the PN stamped on it too....3969835
Jan 19, 2006 | 05:49 PM
Quote:
That makes 2 of us..
Jan 19, 2006 | 08:34 PM
St. Jude Donor '09
It is.
Jan 19, 2006 | 08:39 PM
I made my own heat shield/spacer, mostly for the heat factor. Did not notice any gas savings.
Jan 19, 2006 | 08:44 PM
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
I Want One !
Jan 19, 2006 | 09:30 PM
Quote:
Originally Posted by fotyfobravo
I Want One !
Get yourself a nice piece of cardboard, remove the carb and lay it out. Cut the cardboard so it clears any obstructions on the manifold and carb linkage. Cut out the opening in the manifold and use it as a template on a nice piece of aluminum. Pretty simple and depending on how good you are can look very nice. Just sandwiched it between two carb gaskets.
I made one years ago for my
BOSS 302 to keep the heat of the manifold from overheating the fuel in the fuel bowls. Worked great, looked good and was pretty inexpensive... unless you account for your time!!!
GUSTO
Jan 19, 2006 | 09:47 PM
Thanks Gusto....I will give it a shot.....my time is pretty cheap!
Jan 20, 2006 | 04:34 AM
St. Jude Donor '09
I Want One !
they show up on Ebay from time to time too.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Jan 20, 2006 | 10:08 AM
It is a heat shield designed I believe for the 1970-71 LT-1 with a Holley carb. I tried one from Holley (duplicate of GM design) on my 1967 but it didn't clear the intake runners. I used a 3/8" phenolic spacer instead.
Here is an aftermarket version for a spread-bore.
http://www.jegs.com/webapp/wcs/store...d=11935&CT=999
Jan 20, 2006 | 10:13 AM
It is a heat shield for Holley carbs.
Jan 20, 2006 | 10:44 AM
Here is my heat shield...750 Holley....
Dang...carb is crooked....
Jan 20, 2006 | 11:44 AM
Rich ...
Is that a
Tarantula ?
GUSTO
Jan 20, 2006 | 12:15 PM
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
heat shield
Quote:
if its very thin gauge metal, it definatly a heat sheild. seen them for sure on teh Qjet, didnt know they made one for the holley too
