Brighter Instrument Lights
Old Jan 20, 2006 | 09:27 PM
KALAWAY's Avatar
KALAWAY
Default Brighter Instrument Lights
The instrument lights in my '75, speedo, tach, gauges are very dim. The battery seems to be OK since it's starting the car with no problems. Has anyone changed to a different bulb, or maybe just a newer one, for better results, or is this just what you get with a 30 year old car.
Old Jan 20, 2006 | 09:32 PM
big_G's Avatar
big_G
They shouldn't be very dim. There are 4 bulbs for the speedo, 4 for the tach. Make sure they all are working. Also, make sure the dimmer in the headlight switch is working properly.
Old Jan 20, 2006 | 09:42 PM
indy99's Avatar
indy99
From: the land of a never ending frame-off resto-mod. May Visa have mercy on my soul.
I think as wires age the electron flow becomes slower and slower and that can dim light bulbs and slow down power to the spark plugs too. I would try a Viagro proton injection and see if it helps.
Old Jan 20, 2006 | 10:07 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
I changed mine out and it did help. Even with a 100+ amp alt. I just don't think they are very bright bulbs.
Old Jan 21, 2006 | 07:36 AM
PhotoVette1's Avatar
PhotoVette1
Replacing the bulbs brightened things up considerably in my '77.
Old Jan 21, 2006 | 08:13 AM
KALAWAY's Avatar
KALAWAY
The "Viagro proton injection". Is that for real?
Old Jan 21, 2006 | 08:25 AM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
One of the problems with these cars is that the headlight circuit is fed of the same feed as the instrumentation lighting. Switching the headlights to be fed directly from the alternator through relays (using the stock headlight switch as a trigger) will not only brighten up your interior lights, but your headlights as well.
the definitive article about this is here:
Old Jan 21, 2006 | 05:44 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Did you make sure that your headlight **** is turned all the way to the left?
To Brighter Instrument Lights
