Torq Thrust II definitive guide
Old Jan 27, 2006 | 10:25 PM
  #41
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
That should be some stance when you get them mounted. Can't wait to see some pictures.
Old Jan 28, 2006 | 07:03 AM
  #42
cosmicvette's Avatar
cosmicvette
I will definately post pics when I get them, I am just keeping my fingers crossed that a dock worker doesn't help himself to them on their way downunder.
Cosmic
Old Feb 14, 2006 | 11:45 PM
  #43
DR76's Avatar
DR76
OK, just want to clarify w/ the 15", since not many posted on them...
If going w/ the 15", will the TTII's fit or is the "D" style needed for the shape of the spoke (aren't they both curved?)
What wheel width (and backspace) is recommended for my 235/70/15 Front and 275/60/15 Rear tires (both creeping-up on 28" diameter)? These tires still have PLENTY of meat on them, so hate to trash them, plus I like the full wheel well look.
* I have the VBP fiberglass monoleaf spring and e-brake brackets have been removed...'76
Thanks for the clarifications / recommendations!
Old Feb 15, 2006 | 07:55 AM
  #44
Red73's Avatar
Red73
Originally Posted by cosmicvette
Anyone else with 17" front and 18" rear TTII's that could post a pic?
I am thinking about going 17x8's front and 18x8's rear although I swore I definately would not when I started looking but I figure if I can cram some 255/45R18's under the rear and 245/45R17's up front there will still be a bit of sidewall and a decent rolling diameter, the rear will actually be a perfect 27.0", same as original, the front 25.7" a little smaller than the 26" I was hoping for but the 550 front springs will hopefully lower it a bit in front to compensate......
Cosmic
Here's a pic of mine with 17x8 on the front and 18x10 on the rear.
Old Mar 29, 2014 | 10:10 PM
  #45
doug lewis's Avatar
doug lewis
2nd Gear
Default 79m17in rims
Originally Posted by Corz
I love the look of TT2 but everyones got em. I'm daring to be different and go with the hopsters, I'm assuming the same sizes?
I just bought 17x8 Hopsters w 255/50/17 Riken tires!The front rub on the rear in the finder well when full lock L/R! A 215/50/17 clear , but really like the wide tire,plus a 215 is shorter, Im hoping to cut it back and not cause damage or cause it to crack?? Hope this may help?? Any thoughts on cutting in side back ?? Thank you!!
Old Mar 29, 2014 | 11:50 PM
  #46
kdf1986's Avatar
kdf1986
[/QUOTE]
Jughead, I have always liked the way you made your car. It has a great vette profile.
kdf
Old Mar 30, 2014 | 09:03 AM
  #47
3JsVette's Avatar
3JsVette
Before you do anything take a look at a '78 Pace Car. The front fenders were trimmed at the factory to clear the 255/60-15s which are about the same size as your 255/50-17s. This way you get an idea of what you have to do. If you don't want to start trimming fenders you can drop down a tire size, Try a 245/50-17 or a 245/45-17 rather than going with a 215/50-17.
