aftermarket A/C
Old Jan 21, 2006 | 10:59 PM
gator79's Avatar
gator79
Default aftermarket A/C
I will install an aftermarket A/C in my 71 so the factory components will be comming out. I have the outside box off, does the entire heater box on the inside also come out? there was a post earlier with pics of a install but I can not find it
Old Jan 22, 2006 | 12:14 AM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
On my Hot Rod Air kit the only thing reused is the defrost duct, everything else came with the kit.
Old Jan 22, 2006 | 12:33 AM
majic1984's Avatar
majic1984
http://forums.corvetteforum.com/show...all&forum_id=3
I haven't had too much time to work on mine still - but I will continue with the write-up.
Yes you have to remove the box in the inside.
To aftermarket A/C
