Drop Base Air Cleaner
Old Jan 23, 2006 | 12:06 AM
Fubba's Avatar
Fubba
Default Drop Base Air Cleaner
Looking for a bigger air cleaner. The one on it is not stock, but it has a small cleaner on it. Where can I find a drop base that will fit over an Edelbrock 600 CFM carb? Any ideas?
Old Jan 23, 2006 | 01:25 AM
hoosiervette's Avatar
hoosiervette
St. Jude Donor '14-'15-'16
I got mine from Summit.
Old Jan 23, 2006 | 05:21 AM
guppie's Avatar
guppie
St. Jude Donor '08
I bought an Edelbrock drop base through Napa out of their performance book, took a day to get it.
Old Jan 23, 2006 | 09:37 AM
Paul L's Avatar
Paul L
Why not use the Edelbrock unit? It clears the electric choke.
Old Jan 23, 2006 | 10:44 AM
Fubba's Avatar
Fubba
Where did you get it? I've looked for it and can't find it. Did you get a whole unit and just put the top aside or what? Thanks for the help.
Old Jan 23, 2006 | 10:56 AM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
I bought one from Auto Zone. It cleared my auto choke. 14X3 Larry
Old Jan 23, 2006 | 11:09 AM
Fubba's Avatar
Fubba
I guess I'm so used to having to search around on the internet and through Corvette magazines that I have forgotten the concept of just going to the local Auto Parts store. Thanks for the help guys.
Old Jan 23, 2006 | 12:04 PM
Ron 75 L48's Avatar
Ron 75 L48
I got mine at Advance Auto. I used the Edlebrock and it works great with the 3" K&N element.
Ron
Old Jan 23, 2006 | 12:09 PM
Paul L's Avatar
Paul L
I got mine at a local speedshop.
Old Jan 23, 2006 | 02:59 PM
bams12's Avatar
bams12
Not meaning to steal this post however I love those valve covers on Paul67 's car. Are those available reproduced or does a guy have to buy old stock ? Brent
Old Jan 23, 2006 | 03:32 PM
danboback's Avatar
danboback
I got mine on ebay, mine is an offset one from ebay so that it will clear the HEI distributor. It should be on my doorstep this afternoon!
Old Jan 23, 2006 | 03:53 PM
Paul L's Avatar
Paul L
Brent,
Those covers are available from Paragon for $65.00 each. Then you get out the polishing compound and a buffer. Mine are not chromed.
But for a C3 you will run into PVC/crankcase vent and oil fill issues. These have been addressed in the past and may be available from the archives. It can be done.
Old Jan 30, 2006 | 10:03 PM
Fubba's Avatar
Fubba
Paul67, can you give me a part number on the unit you have? Was it a non-signature series, or did you get the signature series and use a different top?
Old Jan 30, 2006 | 11:49 PM
82MDVette's Avatar
82MDVette
I also have an Edelbrock Carb. (Thunder Series 650 cfm) and am having issues with finding a drop base that will fit!
Does anyone know of a Manufacturer and part # for the base only. I need a 14" diameter and 5 1/8" neck. Not really looking to by a complete setup because I have the K&N X-Stream top and 3" filter that I want to use.
Old Jan 31, 2006 | 12:07 AM
Sprzout's Avatar
Sprzout
Paul, what intake manifold are you running there? I'm looking at doing a different intake than this single plane that the previous owner installed on our car, but I keep seeing that so many of the intake manifolds won't clear under the stock Corvette hood. I'm assuming that's due to running the stock air cleaner, which I'm already considering changing to a drop base cleaner...
Old Jan 31, 2006 | 11:02 AM
davidm_comp's Avatar
davidm_comp
I have an Edelbrock Performer RPM intake manifold, Edelbrock 1406 600cfm carb, and an Edelbrock 14'' x 3'' aircleaner with dropbase....it clears my electric choke fine and HEI distributor, and the hood closes with about .25'' to spare. I also have a .25'' heat gasket under the carb.
Old Jan 31, 2006 | 11:36 AM
82MDVette's Avatar
82MDVette
Paul,
What model Edelbrock Air Cleaner? You have a similar setup to what I am going to be running and yours works good.
To Drop Base Air Cleaner
Old Jan 31, 2006 | 12:06 PM
Paul L's Avatar
Paul L
Fubba and 82MDVette,
That is the Signature Series #1221. I discarded the Edelbrock top and used the original GM/Holley unit.
Old Jan 31, 2006 | 12:21 PM
Paul L's Avatar
Paul L
Sprzout,
That is a GM #3890490 intake used in 1966 and 1967 327/350hp Corvettes. I can't see that it would work on a C3. I would look for its successor: a 1970 or so LT-1 intake. But remember the LT-1 did have a raised hood design.
With the Edelbrock and a 3/8" phenolic spacer (for heat soak reasons) it sits higher than my original Holley. With a small block hood I had to go with a 2" air filter rather than the normal 3". When I had my car painted last winter I had a 427/stinger hood installed and now I'm back to a 3".
Old Jan 31, 2006 | 12:58 PM
82MDVette's Avatar
82MDVette
Paul67,
THANK YOU for your help. I have just ordered the air cleaner assembly from Jeg's.
