3" Exhaust pics, please!!!
Old Jan 25, 2006 | 03:49 AM
breathial's Avatar
breathial
Default 3" Exhaust pics, please!!!
Hey, all. I'm at the point where I need to start building a decent exhaust system on my bruiser.
The engine should be generating somewhere north of 600HP, 575 lbs.-ft of torque... Supercharged 427 BBC. I've got Hedman Husler headers on it, 2" primaries with 3 1/2" collectors. The current exhaust system (left-over from BUBBA ) goes from 2 1/2" to 2" and back... TWICE. It's a MESS, and I know it won't flow worth a darn...
But there's 3" flowmasters welded in at the back (go figure)... Since the flowmasters are SERIOUSLY welded, I'm debating whether to simply trash these, and go with something else... But I have firmly decided to run a 3" system all the way back, and not go for sidepipes...
So, exhaust gurus... Suggestions, please...? And perhaps pics? I would like to achieve maximum ground-clearance, and have the exhaust end at the (approximately) stock location...
Performance goals are simply to achieve the MOST I can with this engine, without being so obnoxious that the local PD pulls me over...
THANKS!!!
Eric
Old Jan 25, 2006 | 09:28 AM
big_G's Avatar
big_G
THANKS!!!
Eric
I think that horse is already out of the barn...
Old Jan 25, 2006 | 11:50 AM
Z-man's Avatar
Z-man
I had a hard time finding anyone who would install a 3" exhaust and guarantee that it wouldn't eventually rattle against the frame on the pass through holes (they must not be as good as the exhaust people who have installed the systems seen on this forum). I used this as an excuse to get the 3" side exhaust pipes that I really wanted anyway. If you want photos, I can give you some.
Old Jan 25, 2006 | 12:24 PM
rihwoods's Avatar
rihwoods
This 3" system is on my 69 502...ignore "X" and "H" pipe combo..I,m still evaluating that install by previous owner.....
Rich
Old Jan 25, 2006 | 01:45 PM
norvalwilhelm's Avatar
norvalwilhelm
I don't have pictures here at work but I do at home. I didn't try to go through my transmission cross member. I modified it to run underneath or actually 1/2 through the bottom of the crossmember and outboard from the stock holes.
I also bought stainless elbows and cut and welded the exhuast together.
3inch is overkill and louder then a smaller 2 1/2 inch system.
I will try to post some pictures this evening.
I also installed cats for the visual inspection you can get on the roadside.
Old Jan 25, 2006 | 02:52 PM
Mickman's Avatar
Mickman
Norval, do we really need cats for our area on the 75' since we're exempt from doing emissions every 2 years? Could we be forced to provide an emission test should the ministry feel the need.
Sorry I forgot I wasn't on my pc, it's
"Maymyvetteliveforevr"
Frank
Old Jan 25, 2006 | 05:36 PM
RocketSapp's Avatar
RocketSapp
On my 76 I have chambered exhaust and it's great. It was there from the prev owner. On the 89 I have 3" pipes... They sound great with the Flowmaster 40s on it. And then there is the other way to run them...
Old Jan 25, 2006 | 07:36 PM
norvalwilhelm
Frank
A 75 came factory stock with cats. There is a safety blitz going on in Kitchener and Toronto and you never know when you are going to be pulled over and inspected.
They have printouts of our cars equipment and your car had better have cats if factory installed them.
It is a $450 fine for no cats and if a cop looks under and sees no cats you can't argue. It is cheaper to buy a pair of high flow cats and have them installed then it is to pay a fine and you have no arguement to use.
Yes a 75 needs cats.
Old Jan 25, 2006 | 07:37 PM
norvalwilhelm
This is my 3 inch stainless exhaust . It is pieced together and tig welded together.
This shows the modified crossmember
This shows the mandrel bent pieces that pass under the rear end.
This shows a overall shot of the 3 inch exhaust. It is tucked nice a tight to the floor boards.
Old Jan 25, 2006 | 07:42 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Here's mine....again
Old Jan 26, 2006 | 04:04 AM
breathial's Avatar
breathial
Some COOL systems!!!
Norval, nice work on your setup. I confess my little MIG (with flux-core wire) won't look as sexy as yours... But with a little practice (and grinder), who knows...?
I do wonder why you say the 3" is overkill, at my horsepower levels. Essentially, I'm running a milder (read that as CHEAPER) version of your engine.... Did you not see significant gains, by going to the 3" system? I admit, this makes me curious... Of course, if the 2 1/2" will do an equal job, then I could buy a pre-bent kit, and adapt it to my car without a lot of the headaches that a 3" system will bring...
Weeelllllllll... Besides having a 6" tall hood "blister" to cover everything except the bug-catcher on top of the engine, I'm hoping to be as mellow as possible... I mean, the car's gonna' be a cop-magnet... Just trying to not stick 'em in the eye too much (or should that be ear?)...
Old Jan 26, 2006 | 09:36 AM
norvalwilhelm
I never compared a 2 1/2 inch to a 3 inch. I jumped all at once with the motor and the exhuast.
3 inch is louder no matter what you do and it is harder to run because of the diameter but it can be done if you take you time.
Flux core wire is never as easy to work with as solid wire and gas.
With the blower you don't need to worry about proper size pipe to engine size. You just need something big to move the spent gas.
Intake port flow, header size and exhuast are critical to a normal aspirated engine but not to a blower motor.
Even the cam within reason is not as critical.
Old Jan 27, 2006 | 04:02 AM
breathial's Avatar
breathial
Yeah, I'm sticking with the flux-core, strictly due to convenience of storage (long story). Not that I LIKE it- it sucks, honestly. But, I use what I have...
I know that superchargers tend to throw all the exhaust theories on their collective ears... But since HP is in directly correlation to the ingestion (and exhaust) of air and fuel, I guess the question I'm really asking is, at what HP level does a 3" system become advantageous? And if I go with a 2 1/2" system at my level of HP, how much am I giving up...?
Any guesses, or heard of any studies on this?
To 3" Exhaust pics, please!!!
