Exhaust Question/Opinions
Old Jan 25, 2006 | 08:19 PM
Eric79-L48's Avatar
Eric79-L48
Default Exhaust Question/Opinions
I am sure this has been asked a million times so I apologize in advance...
On a a '79, totaly stock, with the standard two into one into two exhaust system, including the goofy CAT, what would you performance gurus reccomend I do to improve the exhaust without changing the headers or breaking the bank. Pipes and mufflers are ok but I would really like to keep the stock headers just for originality's sake.
What are your thoughts on this? Am I wasting my money? Do I really need to change the headers? What kind of horsepower increase might I see. I feel like the car is totally choked right now with the stock system and it sounds like crap on top of everything else...
Thanks in advance!
Old Jan 25, 2006 | 09:05 PM
694speed350's Avatar
694speed350
Go to a true dual exhaust system w/o cat if you where you don't have emissions testing. car will sound better.
Old Jan 25, 2006 | 09:47 PM
ltlevil's Avatar
ltlevil
I am assuming you mean manifolds when you say stock headers. If you are determined to keep the original look there are a couple of companies that re-work the manifolds to keep appearance but substantially increase flow. Don't remember the names of them but I'm sure a quick search will get you headed in the right direction.
ltlevil
Old Jan 25, 2006 | 10:08 PM
jetvette's Avatar
jetvette
Just got a quote today for a full flow cat-back system, mandrel bent pipe with Flowmaster. $550 CA legal.
Old Jan 25, 2006 | 10:14 PM
TPL79's Avatar
TPL79
You could also do what I did and remove the cast iron manifolds, clean them up, and store them away. Replace with quality headers (I used Headmann Alumicoat but that was 16 years ago when I installed them). Then run a true dual exhaust system w/o the cat converter.
You will see a measurable increase in performance not to mention sound, and the headers will make it easier to change your spark plugs.
Just my opinion.
Good luck.
Old Jan 25, 2006 | 10:16 PM
rihwoods's Avatar
rihwoods
This is on my 78 L-82...."Y" pipe from stock manifolds changes to 3" thru a 3" high flow cat(carb approved) and 3" back to rear "y" and 2 1/2" out thru Dynamax Super Turbos...there was definately a noticible difference in power...
Pic shows 3" pipe fore/aft of 3" cat....
Old Jan 25, 2006 | 10:24 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
the emission engines can't breathe.....you need to let them breathe and the stock exhaust system is a serious problem....you can not have true performance with out working on this system.....it doesn't have to be "bubbaed" it can be nice and even include cats if yur state requires them
Old Jan 25, 2006 | 11:55 PM
jetvette's Avatar
jetvette
Old Jan 26, 2006 | 08:34 AM
GDaina's Avatar
GDaina
It's illegal to alter the emmissions equipment. However, true duals with hi flo cats achieve the same as duals without cats, yet pass all emmissions tests..
Old Jan 26, 2006 | 08:48 AM
shafrs3's Avatar
shafrs3
I think that's a great way to go, you can justify your true dual exhaust modification to the emissions machine/man, and get a great flowng system.
To Exhaust Question/Opinions
