Interior lights
Old Jan 28, 2006 | 03:44 PM
dstygar's Avatar
dstygar
Default Interior lights
78 Vette, Interior light work if I turn light switch all the way clockwise, however in normal position they do not come one when doors open. Anyone know what the problem might be?
Old Jan 28, 2006 | 04:29 PM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
Do the lights come on when only ONE door is open, which one?
Do the lights come on when both doors are opened?
Sounds like I woud start with the door switches
DonO
Old Jan 28, 2006 | 05:16 PM
kinleydog's Avatar
kinleydog
Sounds to me like the door ajar switches, the door open switches or wiring to either would be the culprit. I've replace all four switches on my '73.
Old Jan 29, 2006 | 08:52 AM
dstygar's Avatar
dstygar
Lights do not come on when either door is opened, will start with the door switches first. However my thought was it would be unlikely both switch would go bad at the same time.
Thanks, Don
Old Jan 29, 2006 | 09:04 AM
rihwoods's Avatar
rihwoods
Check grounds,clean bulb contacts....
Old Jan 29, 2006 | 09:18 AM
BobzVette's Avatar
BobzVette
Does your car have the ZX2 Convenience Group option with the delayed interior light function? If so, the delay timer may be bad.
To Interior lights
