welding question
Old Jan 29, 2006 | 03:21 PM
JustForFun's Avatar
JustForFun
Default welding question
what would happen if you used NON-flux core wire in a flux-core mig welder?
Old Jan 29, 2006 | 03:56 PM
gerry72's Avatar
gerry72
Depends on what you mean. If you mean using MIG wire without the gas, the a lot of sparks and very poor welds. The shielding gas it there not only to shield the weld from reactive elements but also to create a conductive path for the arc. Different metals require different shielding gases just for this reason.
Old Jan 29, 2006 | 04:02 PM
fl_rider's Avatar
fl_rider
As long as you use shielding gas you will be welding with the best of them.
The flux in the flux core wire helps shield the molten puddle while it sets.
With hard wire and shielding gas the gas does the job.
Old Jan 29, 2006 | 10:36 PM
lowbuck72's Avatar
lowbuck72
There is no such thing as a flux core MIG welder. MIG stands for metal inert gas. The inert gas shields the weld so no flux is used. A wire feed welder uses no gas and therefore has to have flux core wire. Some welders can go with or without the bottle. Flux core with gas is redundant, plain wire without gas won't work. My Lincoln .035" flux core wire feed welder can and has done exhaust, frame and body work, and hundreds of patch panels. This is old school compared to Mig and TIG, but a heack of a lot easier than the stick welders, especially on the thin stuff.
Old Jan 29, 2006 | 10:43 PM
jdmick's Avatar
jdmick
Out of curiosity I tried some of the flux core wire when my MIG ran out of gas. No comparison.
Old Jan 29, 2006 | 10:47 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i think i know what you mean and it would not work very well........something would melt but the penetration and any control would be horrible...
Old Jan 30, 2006 | 01:58 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I know a MoPar muscle guy who does that all the time. He somehow manages to get good welds out of it. I told him he's nuts, but I can't complain too much - he sold me a Clarke 110v wire-feed/gas capable welder for 1/3 the asking price...
Old Jan 30, 2006 | 08:10 AM
doopsvette's Avatar
doopsvette
i dont use gas on my mig at all just flux cored wire. I also use a spray that you spray on the job before welding and you get a nice clean weld every time
Old Jan 30, 2006 | 08:39 AM
norvalwilhelm's Avatar
norvalwilhelm
Flux core wire acts like stick. For really nice welding gas is the only way to go. If you weld heavy material and need penetration use flus core.
Old Jan 30, 2006 | 10:58 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Flux core acts like stick WITHOUT blowing holes in everything. At least if you're careful. My 110v Clarke is more than capable of blasting a hole in heavy sheet metal with .035 flux-core wire...
Old Jan 30, 2006 | 11:38 AM
Hvymtlc5's Avatar
Hvymtlc5
If you don't have gas... the no flux core wil NOT weld. It will not penetrate the material just clump all up on the outside.
I learned the hard way..my welder came with this stuff (didn't have the gas bottle attached). Thought the welder was defective - he was
To welding question
