Full Floating Calipers
Old Jan 29, 2006 | 10:50 PM
Carl in LA's Avatar
Carl in LA
Default Full Floating Calipers
I just read another post about mounting drilled discs and wilwood calipers and the poster said they were hard-mounted like stock.
I think we can all agree that the runout on the rear bearings is root of all evil for air in the calipers.
Is there a conversion to make the calipers floating?
If not - why not?
Old Jan 29, 2006 | 11:05 PM
70 LS1's Avatar
70 LS1
There are no kits available. You can convert to C5/C6 style brakes with floating calipers, but the gains are small and it is a lot of custom work.
The only advantage to a fixed caliper is you don't have to worry about bending your caliper. A floating caliper is basically an upside down U that fits over your rotors. If you really apply a lot of force, you could conceivably bend them and reduce your braking. Fixed calipers are stronger and thats why they are used in racing.
