Valve Gaskets Replaced
Old Jan 30, 2006 | 05:16 PM
81 4spd Scooter's Avatar
81 4spd Scooter
Default Valve Gaskets Replaced
Spent last Sunday (solo) replacing the valve gaskets--WOW, what a "pain in the ---!" Too many "other parts" to remove to get to the valve covers. Spent most of the day to remove and replace. However, it was def a learning experience, to include one hose line not knowing where to put back in proper place (believe its in its proper place as the engine runs well, I hope . Replaced while motor in car (just dont have all of the equipment like a mechanic shop has.) While this maybe "novice" stuff to you pros, any tips on how to make it easier for the next 7-10K miles down the road? Thanks in advance...
Old Jan 30, 2006 | 11:04 PM
chris75stingray's Avatar
chris75stingray
theres no way around taking the stuff off. but just think, next time you have to do it you will get faster and faster
Old Jan 30, 2006 | 11:48 PM
A72COUPEDT's Avatar
A72COUPEDT
Default Mr. Mechanic says
MR MECHANIC SAYS....
Mark everything with tape or take pictures!
That is all...
Dave
Old Jan 30, 2006 | 11:58 PM
scotty13's Avatar
scotty13
i used tall winged bolts..it makes it a little easier and you can always snug them on the go...i also liek the look
Old Jan 31, 2006 | 06:32 AM
kb2fzq's Avatar
kb2fzq
Originally Posted by A72COUPEDT
That is all...
Ah...patience, my friend, patience with the newbie....
Old Jan 31, 2006 | 06:43 AM
comp's Avatar
comp
true
To Valve Gaskets Replaced
