I bought my 77 vette last spring. MY differential is out now. I counted my ring a pinion teeth and have a 3.08 final drive ratio. I understand the stock L48 should have a 3.70 ratio. Is this correct? The numbers on the diff are: OA 23 3 W 7E 1 and: 8 gm 3899143 and: 38713 5. I thought it was lacking in acceleration. Before I invest in a 3.70 gear set, I wanted to make sure I have the stock 4 spd trans. The numbers on the trans are:304065903 W.G. DIV. FPC 2 and: 5.11.76.
Any help would be appreciated. I'm a little disappointed but at least the cars performance is starting to make some sense.
In 1977, the L48 base differential was the 3:36 but one could order the economy 3:08. The L82 on the other hand, was base with the 3.70 while the 3.55 was the available economy option.
The OA 233 W 7E 1 code indicates a 3:08 axle ratio (OA) assembled the 233 day of 1977 at the Warren assembly plant (W) on the 1st shift (7E 1). The E indicates an Eaton assembled positraction assembly.
The 233 is a Julian date code which translates into August of 77...consistent with your VIN assembly date.
So...your vehicle was built with the economy axle ratio...base was the 3.36. The 3.70 was reserved for the L82 4 speed.
The aforementioned close ratio trans. has a 2:20 ratio low gear as
opposed to the 2:54 in the wide ratio thus contributing even more to
Your less than stellar low gear performance.The C/R trans. with a 3:70
rear on the other hand makes for a nice combination.I have this combo
in a 79 L 82 and although its not all that fast it is enjoyable to drive
because when going through the gears You can keep the revs up
and it feels and sounds good. Just My .02 cents worth.
Yes the 370 was the optional L-82 gear. typically the L-48 had the 336 with 4 spd and 308 with auto. Did you find the stamping on the ring gear?
You can run the 370 or 373 gear with a WR M-20 or M-21 CR. The acceleration w/M-20 will be better in 1st gear but the CR is better suited for road racing applications where you want to the RPM band closer. For street use the M-20 or a 5-spd would be great.
great feedback, thanks to all.
Hey Chevylit, are you running around 3500 rpm at 65 mph?
Yep,running 255/60 tires and its turning right at 3500 at 65. Thats
about the only thing thats not too swell about having a 3:70 rear.Guess
thats why there's so much swapping to overdrive transmissions.
