nothing other than a premier brand of car care products. the reason you are probably unaware of it is that they don't flood the market with advertising and have been known to refuse to sell to someone at their whim, lol!
Why are you removing Zaino? Don't like the results? The reason I ask is I have a box full of stuff from them -- their whole process I guess, I have not used it yet - because it takes so long to do - Now you are making me wonder if I should NOT use it.
Did you not read the initial post?? when doing body work and repain you need to remove all coatings so it wont hurt the new paint application.
thanks to all for your help I thought I heard once that dawn would strip it off just wanted to make sure. I will be using ZAINO on my newley painted 75
It is not clear to me that Dawn will completely remove the old Zaino. They recommend washing your car with Dawn (until the dirt is gone.... dada) as the first step in the Zaino process, but it is a leap of faith to suggest that the Dawn will remove all old Zaino. I would call up Sal Zaino and ask him how best to remove the old stuff prior to body work, or repaint or whatever you are doing.
Just the normal white spirit degreaser will remove it. You have to prep anyway with this or similar stuff before painting to remove all grease etc.
I had no problems redoing small areas like that and you can keep the Zaino removal area small.
