Torque on Wheels Lug Nuts?
Old Feb 1, 2006 | 06:31 PM
c3andc5's Avatar
c3andc5
Default Torque on Wheels Lug Nuts?
Any of you happen to know what the proper torque is on the lug nuts for the 73 w/OEM wheels? Nothing in my Owner's Manual or my Haynes (lame) Manual.
Old Feb 1, 2006 | 06:36 PM
big_G's Avatar
big_G
My '68 Chevy shop manual says 65, I use 85 ft/lbs.
Old Feb 1, 2006 | 06:42 PM
Frankenvette's Avatar
Frankenvette
with my C5 wagon wheels I'm also around 80-85 ft/lbs.
Old Feb 1, 2006 | 09:10 PM
GUSTO14's Avatar
GUSTO14
big_G...
Why do you suppose GM calls for 100 ft/lbs on the C5? I have a friend that stripped 3 of the studs on his 2003 using a calibrated torque wrench at 100 ft/lbs. He even had the wrench rechecked after this disaster. I'm confused as to why the big increase since the studs are so close to the same size...
Curious... GUSTO
Old Feb 1, 2006 | 09:25 PM
big_G's Avatar
big_G
Not the same size...C-3 is 7/16, C-4 and C-5 lugs are 13 millimeter. (About 1/2 inch.) I have never stripped a C-4 or C-5 lug/stud at 100 ft/lbs., and I've torqued more lugs than I care to remember. I don't know why your friend had that trouble.
Old Feb 1, 2006 | 09:56 PM
GUSTO14's Avatar
GUSTO14
Actually my C5 has 12mm studs which come out to .47 inches while the 7/16 equals .44 inches. They are larger, I just didn't think they were large enough to warrant a 17% increase in torque.
I sort of assumed he must have set the torque wrench wrong since I have torqued them to 100# and never stripped one... I'm just not comfortable doing it in light of the torqe required for earlier Corvettes.
Thanks... GUSTO
Old Feb 1, 2006 | 11:17 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
My torque chart has it at 70-90 ft/lbs for aluminum wheels and 65-85 ft/lbs for the steel wheels
Old Feb 2, 2006 | 12:15 AM
IrishJoker's Avatar
IrishJoker
Old Feb 2, 2006 | 05:29 AM
c3andc5's Avatar
c3andc5
I guessed on the side of caution and did 70lbs. Looks like I was close. Thanks,
Chris
Old Feb 2, 2006 | 01:18 PM
Tele_Man's Avatar
Tele_Man
I've got Cragar SS wheels and I torque the lug nuts to ~95 ft lb.
Old Feb 2, 2006 | 03:19 PM
Kalway's Avatar
Kalway
I just push on the bar until they feel tight enough...
Old Feb 2, 2006 | 04:39 PM
lowbuck72's Avatar
lowbuck72
Remember that the torque specs assume you have clean dry threads with no binding. Oil on the threads will give a false reading. Also make sure there is no rust on the hubs or back of the wheels. Lastly, always use a star pattern when removing and installing wheels. In fact put your lug nuts on in a star pattern snug, then torque them down in the same pattern. Many manufacturers have a +/- 20 ft-lb range. For example, Chrysler products with a 1/2" stud recommend 85-115 ft-lb. Many Hondas, Toyotas, Mazdas, and GM vehicles all have 12 X 1.5 mm studs, however Honda says 80 ft-lb, Toyota says 76, Mazda says 87 and GM says 100, go figure. ( I do this for a living, I know these specs by heart.) The 7/16" studs on older Chevy's should be 80-85 ft-lb.
Old Feb 3, 2006 | 05:27 AM
c3andc5's Avatar
c3andc5
Good advice. Thanks
To Torque on Wheels Lug Nuts?
