Hoooker sidepipe header questions
Old Feb 2, 2006 | 01:48 PM
PolishMike's Avatar
PolishMike
Default Hoooker sidepipe header questions
Hey guys,
I have a 75 with a zz502 in it. Im test fitting my headers and im not able to get them on. I was using 3 long bolts and un doing one, adding washers, ect to bring the headers closer. I have it pretty close but its a bit to far to use the supplied bolts and it just wont go. I really dont feel like stripping the threads. Is it possible that the holes in the flange arent perfectly aligned? I have it really close but it just wont go. Any tips?
Next question - anybody use these with an ecu that needs an o2 sensor. I have a wideband sensor for my accel dfi (superram). I really cant think of a place where it wont be ugly. I know i need it where all the pipes come together. Any way to hide it or am i just going to have to live with seeing one?
one more - I have the keisler tko-600 kit and the tranny yoke is hitting the tunnel. Can i move the engine more to the drivers side by loosing the mounts and trying to move it with the cherry picker?
Thanks guys
Mike
Old Feb 2, 2006 | 06:29 PM
PolishMike's Avatar
PolishMike
ttt
Old Feb 2, 2006 | 07:38 PM
84rzv500r's Avatar
84rzv500r
I welded the O2 sensor bung in the #8 header tube in the middle of the part that is parallel to the ground by the starter. Be careful as the frame is close....
It would be better in the collector...
Old Feb 2, 2006 | 11:16 PM
panchop's Avatar
panchop
i think you would be better off trying to shift the body a LRH. your net going to geta lot of movment on the motormounts. don't force the headers. something ain't right. you would just be streesing them and they wioll crack.
Old Feb 3, 2006 | 01:21 AM
PolishMike's Avatar
PolishMike
Thats what i figures. I do have the poly mounts on there now, would that make that much of a difference? I dont think so. Any tips on moving the body???
Old Feb 3, 2006 | 01:24 AM
PolishMike's Avatar
PolishMike
I dont see how that could be accurate. Your o2s will probably jump all over the place as its reading the pulses and not the true o2 signal. An ideal set up would be one on each side but i really dont want to do that. Ive done several EFI engines with wideband but with this car the sidemount headers really represent a problem. I guess ill have to live with it though.
Old Feb 3, 2006 | 01:58 PM
CGGorman's Avatar
CGGorman
Isn't the zz502 a tall deck block? That will screw you up big time if you headers run as close to the frame as mine do...
My O2 sensor bung is welded on the inboard side of the passenger collector. It's tilted up at about 10 o'clock. Can't see it and it won't get hit by anything.
Old Feb 3, 2006 | 10:32 PM
PolishMike's Avatar
PolishMike
Is it?? Lol shows you how much i know. All i know is the headers i got are listed for a 502. Called hooker to confirm and they said it should be fine. Now im not sure though. Am i screwed?
Old Feb 3, 2006 | 10:36 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Are the headers hitting something? When I installed mine they hit the bottom of the fender right behind the front tires. I am not sure when the body changed. My hookers hit the steering box the fenders the frame and the A/C coil box.
Old Feb 3, 2006 | 10:39 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Did you trim the rocker channels? Maybe there htting there.
Old Feb 3, 2006 | 10:44 PM
chevymans 77
I pretty sure the 502 is a regular deck height block.
Old Feb 3, 2006 | 10:52 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I think so too.
Old Feb 4, 2006 | 02:21 AM
PolishMike's Avatar
PolishMike
I think thats what i have to do.
Old Feb 4, 2006 | 11:19 PM
Robert Hall's Avatar
0Robert Hall
Former Vendor
Originally Posted by PolishMike
Hey guys, I have the keisler tko-600 kit and the tranny yoke is hitting the tunnel. Can i move the engine more to the drivers side by loosing the mounts and trying to move it with the cherry picker?Mike
Mike -
Just give our tech line a call on Monday morning. 865-609-8187 press option #2
The Keisler tranny kit wil fit just fine if the rest of the drivetrain is positioned properly.
Robert
Old Feb 4, 2006 | 11:35 PM
CGGorman's Avatar
CGGorman
You're right. I looked it up. It's 9.8" My bad.
Regardless, you might have to trim some of the rocker to clear everything.
Old Feb 5, 2006 | 02:21 AM
PolishMike's Avatar
PolishMike
Thanks for the scare had me sweatin a little. This car is going off to paint really soon and maybe even starting before. Sorry if i start an earthquake LOL mmmmm efi+zz502+open headers
To Hoooker sidepipe header questions
