Recomendation on Points to Electronic Distributor Conversion?
many people feel their motors aren't running to peak performance so install electronic conversions and claim they can feel a difference. The electronic conversion units are simply helping to mask the underlaying problems that were already in the system.
if these problems had been properly corrected to begin with by setting up the distributor correctly, rebuilding it to get rid of distributor shaft endplay, or whatever the problem is that's causing the motor to not perform at peak level, than you would not feel any difference from the points system to an electronic conversion.
keep in mind the basics, there is no magic happening here. all the elctronic conversions are doing is replacing an electro-mechanical switch for the coil (the points) with an electronic switch. they do NOT give you a "hotter spark" - that comes from the coil, not the distributor.
If someone feels a difference in the cars performance after switching to an electronic conversion than they would have felt the same difference if they had replaced their older points.
The GM HEI distributor is a completely different story and GM developed that out of a need for a hotter spark because of changes in the motors during the mid 70's from emmision requirements and TRYING to keep some performance on the cars. The HEI was far from a perfect solution but it filled a need at the time.
Considering $65.00 for the XR-1, and if you upgrade the coil for $40.00 you can buy a brand new Summit HEI for $139.00 and probably get severals years a service out of it considering yhe mileage on collector cars annually.
If these conversions have optical sensors, they are in an environment where dirt and oil can cover the optics and cause the part to malfunction.
I don't even see the need to upgrade the older motors that came originally with points distributors with HEI units. The HEI units were for models that needed the hotter spark. Motors that came with the HEI units had much different timing set-up to try and increase fuel ecomomy and the hotter spark from the HEI units was needed to help proper combustion. The motors prior to that that came with point distributors didn't need the HEI and really won't benefit very much, if at all from installing it as I understand it.
