Failed Inspection Today
Old Feb 3, 2006 | 11:59 PM
Higs's Avatar
Higs
Default Failed Inspection Today
Help Please! Failed state inspection due to "no high beam and turn signal indicator lamps". I have lights on speedo and tac. Must be the center cluster between. Any help would really be appreciated.
Frustrated in Houston.
Old Feb 4, 2006 | 12:05 AM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
assuming you checked the bulbs, i would next try to clean the connections. Mine have gotten corroded in the past and need some contact cleaner and a little filing to clean up. Sometimes the connector is just shot. You can get replacements at most auto parts stores. Just cut the old one off and splice the new on. You might need to spray some contact cleaner on your high beam switch.
Did the high beams and turn signals ever work for you?
Edit: are you saying they failed you for the indicators on the dash not working. **** retentive bastards. You'll have to tear apart your dash. Or just take the damn thing somewhere else.
Old Feb 4, 2006 | 12:59 AM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Or get an Antique license - no inpsections required, ever. *1 & down qualify (25 yrs old)
Old Feb 4, 2006 | 05:49 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Turn and high beam signals should be in the tach and speedo.
Old Feb 4, 2006 | 07:49 AM
Higs's Avatar
Higs
The High Beams and Turn signals work fine. Just the dang indicater lights between the spedo and tac. Would each of these have a seperate bulb? Does the blinker/high beam switch in the column control these idicators? Just looking for a place to start finding the problem.
Old Feb 4, 2006 | 08:11 AM
rihwoods's Avatar
rihwoods
Seems if signals work,your column switch is ok...just a problem with indicators....could be bulb or ground....
Old Feb 4, 2006 | 08:20 AM
C3 4ME's Avatar
C3 4ME
probably just bulbs. My high beam indicator didn't work either when I got the car, and that's what the problem was. If you take the tach/speedo cluster out, I'd suggest replacing every bulb while you've got it out.
Old Feb 4, 2006 | 08:29 AM
Higs's Avatar
Higs
Thanks, now I know what I will be doing after the yard work and before the pre-superbowl party. Bulbs available at parts house?
Old Feb 4, 2006 | 08:41 AM
rihwoods's Avatar
rihwoods
Yes they are..just match yours..you may be able to wriggle your hand in there and get them out...may be just one bulb....
Old Feb 4, 2006 | 11:45 AM
KALAWAY's Avatar
KALAWAY
I had the same problem on my '75. Turn signals and emergency brake work fine on the car but not the lights in the dash. Turns out the brake light bulb was out of position (it came out of its hole) and the right turn signal light was burned out. I couldn't reach them though w/o pulling the drivers side of the dash. Not fun.
Old Feb 4, 2006 | 06:58 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Your car takes 194 bulbs. Remove the screws holding the face bezel and remove the black bezel from the speedo/tach and they are right there.
To Failed Inspection Today
