82 Glovebox lock
Old Feb 4, 2006 | 08:00 AM
rafto's Avatar
rafto
Default 82 Glovebox lock
How do you tighten up the lock mechanism on the glove box door. There has to be an easy way to remove the ****.
Old Feb 4, 2006 | 08:11 AM
Higs's Avatar
Higs
That's on my list too, but have not done it yet. Maybe someone will let us know.
Old Feb 4, 2006 | 08:24 AM
icanfixitforyou's Avatar
icanfixitforyou
I believe you need to insert the key in the lock, twist and pull by hand and the thing sort of separates into 2 pieces, the chrome faceplate that you see, and the white-metal lock cylinder. Now you can access that skinny nut that holds it in place. If you need a replacement, I got one at Zip for a fair price.
Old Feb 4, 2006 | 08:27 AM
Frankenvette's Avatar
Frankenvette
I have an article explaining it. If I can find it I'll post it here if no one else responds first.
Old Feb 4, 2006 | 08:32 AM
Higs's Avatar
Higs
I hope that one day I can help out a newbee like you guys do. Thanks for the information.
Old Feb 4, 2006 | 10:08 AM
rafto's Avatar
rafto
Tried the key in the lock. Couldn't get it apart.
Old Feb 4, 2006 | 10:10 AM
Frankenvette
If you will provide your email address I can email you an article on glove box removal. It details how to uninstall your lock. By doing so you can simply reverse the procedure to reinstall which will also allow you to tighten it up.
Jim
Old Feb 4, 2006 | 10:39 AM
rafto's Avatar
rafto
Email sent.... Thanks
Old Feb 4, 2006 | 06:17 PM
guppie's Avatar
guppie
St. Jude Donor '08
There is a small hole on the side of the lock, a thin punch or something small needs to be inserted in the hole then it will release
I almost forgot, The key needs to be in the lock while you're doing this.
Old Feb 4, 2006 | 06:34 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Does this help....
http://forums.corvetteforum.com/showthread.php?t=568860
Old Feb 4, 2006 | 07:20 PM
gr8whte's Avatar
gr8whte
St. Jude Donor '05-'06-'07-'08
Originally Posted by Glass Act
Tremendously, I've gotta tighten mine too.
Old Feb 5, 2006 | 07:37 AM
rafto's Avatar
rafto
Great. Thanks much.......
Old Feb 12, 2006 | 11:38 AM
jsera's Avatar
jsera
Please send me a copy to jsera7885@aol.com
To 82 Glovebox lock
