factory side pipes
Old Feb 5, 2006 | 10:45 PM
trooper39's Avatar
trooper39
Cruising
Default factory side pipes
Hey hows it going! Noobie here And I need your help.
I have a 69 vert 350hp and I have all the parts ready
to switch to factory pipes.I did'nt have the money to boot
for crome covers,has any one had any luck painting fiberglass
covers to look right?Any tips about the change over would be great!
Thanks!
Old Feb 5, 2006 | 10:52 PM
GDaina's Avatar
GDaina
Get a quart of catalyst primer, such as Slicksand. Spray, sand and apply the color of your choice.
Old Feb 5, 2006 | 11:24 PM
trooper39's Avatar
trooper39
Cruising
Any luck with crome paint?
Old Feb 6, 2006 | 01:26 AM
GDaina's Avatar
GDaina
No different than any other paint, just mix it well and watch the runs.
Old Feb 6, 2006 | 10:43 AM
trooper39's Avatar
trooper39
Cruising
Cool! I saw somewhere in the forum that I would have to trim
the fiberglass to make the pipes fit correctly,is that the case?
Old Feb 6, 2006 | 04:35 PM
GDaina's Avatar
GDaina
Could be...dry fitting the covers before painting should be the primary priority.
Old Feb 6, 2006 | 04:42 PM
NHvette's Avatar
NHvette
I've never heard of trimming them.
My buddy had the 'glass covers on his '73 with original
'69 sidepipes. The bottom edge of the covers did rest on the
pipes. Over the course of several years, the fiberglass was
worn/burned on that edge. You couldn't tell unless you got
down on your knees and lifted the cover outward.
Go for it .. test fit first before painting.
IMHO - they look good painted to match the color of the vette.
Old Feb 6, 2006 | 06:14 PM
trooper39's Avatar
trooper39
Cruising
Thanks for the tips,I want to do it right the first time
not redo it right on the 4th try!
To factory side pipes
