head light switch removal
Old Feb 6, 2006 | 05:46 PM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
Default head light switch removal
how do get the head light switch **** off the shaft or does the shaft come out of the switch somehow??? as i dont want to pull on it too hard and damage something???
Old Feb 6, 2006 | 06:07 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
There is a little spring-loaded button on the switch body. Press it, and the **** will come right out. All GM headlight switches were like that for many, many years.
Old Feb 6, 2006 | 06:24 PM
ksbunting's Avatar
ksbunting
If you loosen up the dash pad enough to allow access to the spring loaded button on the back of the switch it is a little easier. As Batman said, the **** will pull out and the shaft, whihc is probably 2-3 inches long, comes with it as it is permanently attached to the ****.
Kurt
Old Feb 6, 2006 | 07:29 PM
79 vette head
St. Jude Donor '10
thanks i will try that you guys are great!!!!! batman & ksbunting
To head light switch removal
