Rusted Pipe
Old Feb 7, 2006 | 06:11 PM
RequiemNightmare's Avatar
RequiemNightmare
Default Rusted Pipe
I'm was trying to take off my old stock mufflers a bit ago and I noticed its almost impossible to just take them off because it seems the pipes are partially rusted to the mufflers....anyone got an idea to get em off other than cutting or welding?
Old Feb 7, 2006 | 06:32 PM
houstonvett's Avatar
houstonvett
St. Jude Donor '09, '24
Summit sells an exhaust pipe seperator which works well. Very simple idea that works, houstonvett
Old Feb 7, 2006 | 06:36 PM
RequiemNightmare
I just thought, what about a large pipe wrench would that work?
Old Feb 7, 2006 | 06:43 PM
NHvette's Avatar
NHvette
Best bet is to use a dremel or cutoff wheel to make a slit along
the overlapping pipe. You only need to make the slit from the
edge of the overlap to just past the area that the clamp was on.
Once you get that far, often the pipes can be wiggled and
twisted enough to come apart. Going back together could be
welded or (that far away from engine) hi temp RTV to seal it
before throwing the clamp back on.
Worst case is the overlapping end gets buggered up and you have a new short piece of pipe welded onto the end.
Best case is you replace with dual exhaust or sidepipes.
Do you have an automatic (forget from pics) ? If so, consider
dropping the entire system with the tranny crossmember.
Then, you can mess around with it off of the car .. much easier
and what I did.
Old Feb 7, 2006 | 08:12 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Are you replacing the Y pipe or mufflers? If not, pull the whole thing at the cat converter, that's what I have done. Otherwise, you'll probably have to cut either the outside and wreck the muffler or cut the Y off flush at the muffler and cut and bend out the remaining piece from inside the muffler inlet. Either way, I'd also pull the whole thing at least at the converter and work on it off the car.
Mike
To Rusted Pipe
