Shim Placement
Feb 8, 2006 | 09:14 AM
Shim Placement
When shimming a hood where do the shims go, between the hinge and the body or between the hood and the hinge?
Can I shim the rear latches (close to the windshield) so I don't have to push the hood down so far for it to lock?
Feb 8, 2006 | 09:34 AM
1: Shims go between the hinge and the body
2: You can also put shims between the hook on the hood and the hood to change the closed position height. With a new hood seal, it might take a little force to close.
Feb 8, 2006 | 09:44 AM
What I thought.. thanks...this is a tedious job
.....building the motor and tuning was fun...I may save this stuff for the body shop to do.
Feb 8, 2006 | 11:12 AM
Aren't you supposed to set the rear height with the
threaded adjustment on the latch and bumper ?
... never heard of anyone shimming the latches.
Rubber spacers are used along the gutters to keep the edges aligned.
Feb 8, 2006 | 11:23 AM
Quote:
Aren't you supposed to set the rear height with the threaded adjustment on the latch and bumper ?
Where is the threaded part on the latch your referencing?
Feb 8, 2006 | 12:03 PM
Quote:
The ***** part is threaded, too ...
http://www.zip-products.com/Zip/prod...349683ECA08A20
.. you just don't notice it under the spring.
Most would be rusted or corroded a bit ... best to use penetrating oil
and some heat to get it free.
Feb 8, 2006 | 12:10 PM
Quote:
Originally Posted by NHvette
78-82 use a hook, chevy adds shims as necessary.
Feb 8, 2006 | 02:50 PM
That's what I have ..need a few more shims.....
Feb 8, 2006 | 06:08 PM
Quote:
Thanks for the info. I thought all C3s were same latches.
I'll have to find someone local with a late C3 to check 'em out sometime.
