I have a mostly stock '79 L82 with air. I am starting to do dress up work in the engine bay and I am thinking that my next purchase will be a crome air filter cover. I am going to pull out all the plastic cool air induction pieces and want a nice looking crome cover. I was thinking of going with the K&N set up and was wondering if I needed a drop base to fit under the hood (I have seen them in other discussions). The hood insulation is long gone and I kind of like that look - so I am not thinking that I will put it back in.
What is the general opinion out there. Pics would also be helpful.
There has been engine work done by bubba but I have not done any yet except for maintenance. It looks like a stock one but I am not 100% certain. If I had to put $$ on it - I would say stock. As to the specifics, I do not know.
My future plans are to build an engine and drop it in - that will include more actual performance parts. Currently all I want is dress up parts.
Dual snorkle cold air induction is the way to go. Leave it on, and buy a chrome top, if you must.
My problem is I cannot fit the cold air induction, with a RPM Performer, under my hood.
THis is more a cruizer that a preformer. I want as much stuff to shine under the hood as I can get. My plans are to build a 383 in the next couple of years which it will probably have an intake with longer intake runners - remember in the future. That motor will have a serpentine belt setup and as much polished billet as possible. Most of the shiney goodies should be able to be swapped over and some would be ok either way - like a master cylinder. I am in the process of filing the emissions stuff into can #13 - lucky me being in MS and having an antique car.
I know that cool air = more hp - but what am I looking at if I were to remove it - what kind of reductions.
Should I care about the reductions if I am just cruizin and not racing.
Cold air = power.
Glen242, if you want cold air, then the answer is simple, get a taller hood & use cowl air. The factory set up is junk for high perf use. It was designed for fuel economy & emissions.
Are you saying that, given a choice, you would use an after market open element air cleaner over a stock dual snorkle air cleaner?
The discussion was not about cowl induction hoods, etc., but removing the stock dual set up in favor of a lot of chrome pieces.
------------------------------------------------------------"Its fine if you have 200 hp."
What a stupid thing to say! Expect statements like this from an A**H***.
See if this link works...this is what you be lookin for....I took off my stock dual snout and use this....noticable DIFFERENCE...better perf/sound/economy
