Wierd problem with the brakes. Work OK a normal speeds. When I get down to under 5mph, the brake pedal goes hard and the don't work so good.
Any ideas?
I have had a new air cleaner fitted and it needs a tune up (running lean). So, it has a very low idle and cuts out if I don't pump the gas a bit when stationary. Could this be related?
The vacuum to the booster is not getting enough to provide you with the assist. Find the vacuum leak or get the car tuned so you have some decent vacuum at idle and you should be OK
