Fluid Change Question
Old Feb 18, 2006 | 08:51 PM
Flying Ace's Avatar
Flying Ace
St. Jude Donor '05-'06
Default Fluid Change Question
I'm going to change the trans oil in my '81 and replace a leaky gasket.
What's the best way to drain the fluid?
Also, I have a small leak on my oil pan as well...is it a pain in the butt to replace those gaskets as well?
Thanks for any help.
Old Feb 18, 2006 | 08:54 PM
Sayfoo's Avatar
Sayfoo
What kind of trans? You may have to partially disconnect your steering rods in order to remove the oil pan, but it's not too bad.
Old Feb 18, 2006 | 08:56 PM
Flying Ace's Avatar
Flying Ace
Oops! Auto transmission...
Old Feb 18, 2006 | 09:13 PM
Flying Ace's Avatar
Flying Ace
How much transmissio fluid does the Automatic hold?
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
just loosen the trans pan and it will start to drain....then remove all the bolts and take the pan down....get a filter kit with new gasket and you are good to go.....and yes the torque converter is still filled with old fluid
Old Feb 18, 2006 | 09:24 PM
Flying Ace's Avatar
Flying Ace
Thanks much!
To Fluid Change Question
