I just put my 68 on jackstands and they are in the right spots but the passanger door is hard to close, should I worry or just leave the door shut intil I get done with everything I have it in jacks for???
there is a lot of flex in the vette body. I would leave the doors closed & windows down, can't hurt to take the t-tops off or drop the vert top. I would move the jack stands to center the car better & make sure they are all at the same height level.
Really now? I was reading a thread a while back on this - are we sure this is just not an urban legend? I think the frame under a C3 is pretty darn stiff if you ask me, does it really flex as much as has been mentioned here? Windows popping out, T-Tops cracking, doors not closing? I mean let's look as this logically, if in the course of history - from jacking the C3 up throughout its long reign that if what has been said happens really happens, i.e. windshields cracking, popping out, T-Tops cracking, doors - what - sticking or something (I haven't figured this one out yet). Do you really think that owners would not have been complaining to Chevrolet? "Hey I had to jack my car up because I got a flat and my windshield popped out, what gives?" I don't recall any warning other than using the jack points as explained in the owners manual. Does anybody have any real life experience with "Bad things happening" to your C3 when you jack it up as described in the owners manual?
All I can tell you is that my 68 is on jack stands right now The jack stands are at the same height, And I have them in the location as perscribed by the Factory workshop manual and my passenger door is sticking big time, I can get it open and closed but it's work. As far as someone complaining to Chevy I am sure they want to hear about a 39 year old car, maybe they did not twist when they are new, I know I can't do the same things I did 39 years ago. I can tell you my passenger door is stuck . I have the t-tops out and the window down. Thanks for the advice.
Actually, I wasn't talking current time frame - but more around when your car was new - about complaints that chevy may or may not have gotten about body flexing.
If they were having problems when they were new, you think their would be more about, but maybe people did not conplain then like they do now,thanks for your help. My first glass car and I am afraid of braking it, but I guess if it lasted all these years it can survive me.
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Logic or no when having an old C3 up off the wheels either on jack stands or lift bad things can happen. only heard of the window popping out, but have seen one damaged, and depending on where it is lifted the door will acutally get stuck till back on the wheels. never done it with a ragtop though and i imagine the dynamica are a bit different.
Its a matter of physics and dynamics.
tim
maybe the frame is weakened by rust? I had mine down to the frame and the frame seems pretty stout to me. I have had this happen on unitized body (non frame) cars.
I had mine on stands for 6 months and noticed it "sagging: a little bit. I put my jack (with a block of wood) under the front cross member and just gave it a little support under the nose. This also helped the doors out tremendously. I did however have the tops out, hood popped and doors ajar. just my.02
Hate to say it, but I have had mine jacked up with one jack....two jacks tipping it on it side and numerous other unorthodox ways...before I read stuff like this on the forum. I didn't take the tops out and I opened and closed the door(s) as I worked on the cars. It may not be the best way to do business, but I have had no problems with anything cracking or popping out because of the way I did it. It does have a steel frame...........I will pay more attention to having the jacks equal if it is stored up in the air for a period of time (didn't do that last time it was in the air for 2 months).
I have lifted it on one side only, front or rear only and have had no problems doing it that way. I only noticed the doors getting slightly difficult to open and close after a few months of beiing in the air. I saw a thread similar to this one back then and decided to take all of the suggested precautions so I would not have any additional problems.
I will now do this only when it is out of comission for a while.
I think it makes a big difference on weather it's a coupe or convertable. I can jack up the wife's 82 with no apparent flexing at all. Everything opens, closes, etc as normal.
My 71 vert on the otherhand flexes when jacked up. You can't open or close the doors.
Well I guess what happen to my 78 SA may fit with this topic. While up on a lift getting the oil changed (doors open). The so called knuckel head slams my drivers side door (trying to close it) and caused a serious paint and fiberglass chip. Only the size of a silver dollar. Lesson learned for me, know who is working on your vette but trust not many....
If you jack your C3 up and the door hits/rubs/sticks
when opened and closed, you have some sort of frame and/or
body rot. Mine was exactly as you describe, and after doing
a body-off, I realized how unsafe it was.
My newly restored (solid) frame does not have these problems.
Should you open the door before jacking ? Yes, if you don't know
the condition of the frame and birdcage.
Should you have your vette looked at if it does this ? Yes.
Here are a few pics of the frame/BC that did "flex":
The convertables by their design are not as stiff as a coupe. Having a roof even if its a t-top stiffens up the box.
If you were to look at the door jams on a convertable you would see a extra piece of harware not found on coupes. It's a round tapered receptacle that a pin on the door fits into to stiffen up the body when the doors are closed.
One of the things to look for when buying a vert is if any of these pins are missing or broken from excessive flexing if the car was hit hard.
