Frame Rust?
Old Feb 22, 2006 | 12:51 PM
78SA's Avatar
78SA
Default Frame Rust?
I'm going to look at a 78, what area of the frame do i look for rust and does anyone have pic's? .. thanks Ray
Old Feb 22, 2006 | 01:01 PM
DC118us's Avatar
DC118us
Definitely look underneath the rear of the doors, in front of the rear tires, that seems to be the first place the frame begins rusting.
Old Feb 22, 2006 | 06:18 PM
shafrs3's Avatar
shafrs3
The radiator support frame will give some clues. If the car has been sitting a while, tap along the frame rail under the door with a hammer, if there is serious rust large flakes will drop out from the the factory holes. And speaking of factory holes, stick a finger into these holes and feel around for rust. Surface rust feels like fine sandpaper. The more serious type feels much more coarse, like 100 grit. Look on the back side of the bumpers. With a screw driver poke the frame around the area in front of the rear wheels just below the trailing arm, if it polks through you've got some substantial rusting. Look inside the door jamb above the top door hinge below the windshield frame for evidence of bird cage rust.
Old Feb 22, 2006 | 07:16 PM
78SA's Avatar
78SA
Thanks guys for your response and your time, great board! thanks thanks ... Ray
Old Feb 22, 2006 | 11:17 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Bird cage rust is as bad or worse then frame rot, and more likely to happen. Pull the kick panels, rear wheels, and inspection panels in the rear wheel wells. Look really good at the #2 and #3 body mount locations. piles of rust on top of the mounts indicates rust falling down from above (windshield frame or pillar posts). Rot around the body mounts indicates the rocker channels are thrashed. Those will take a frame off to fix. Take a pick or scratch awl with you, if you can poke though the bottom of the radiator support it would be a good idea to very closely inspect everything else. These cars can be complete rust buckets but still look really good on the outside.
Old Feb 23, 2006 | 08:39 AM
78SA's Avatar
78SA
Thanks Fish, Really good info there, i appreciate it .. Ray
To Frame Rust?
